BAR'S LEAKS LIQUID COPPER HEAD GASKET / RADIATOR / INTAKE MANIFOLD / BLOCK SEAL.
One Step, No Draining Required
Coolant Compatible Sodium Silicate Formula
Permanent Cooling System Repair
Repairs & Seals Blown Head Gaskets
Repairs & Seals Engine Block Leaks
Works with All Types of Coolant or Water
It’s part of life: older cars, trucks, vans, SUVs and even RVs can develop large leaks in their radiators and intake manifolds. If you’ve tried regular stop leak products you know they are not powerful enough to stop these larger leaks. That’s why Bar’s Leaks designed the Liquid Copper Block Seal Intake & Radiator Stop Leak. This one-step sealer was designed to quickly and safely stop these overwhelming leaks.
What it does? Our formula permanently repairs larger leaks in radiators, intake manifolds and gaskets, heater cores, blocks, heads and freeze plugs. It contains an antifreeze-compatible sodium silicate liquid glass formula, so no draining of the cooling system is required. Not to mention, it will not harm the cooling system when used properly.
Their stop leak products can’t get your show back on the road like Bar’s Leaks — that’s why we’ve been the most trusted stop leak brand since 1947. Make sure to watch Bobby and Caitlin in our handy how-to video so you can become a “three- minute mechanic” and finally take control of that leak. (Please watch video below).
Part Number: 1109
Dosage: Use – 1/2 bottle in a small cooling systems, such as 4 cylinders with no A/C. Use 1 bottle for regular size systems, which are most 4, 6, 8 and 10 cylinder engines. For larger systems, use 1 bottle for every 6 gallons of cooling system capacity.
Size: 18 oz. (510ml).
FAQ
Will it work in the existing coolant?
Yes, Liquid Copper™ is compatible with both conventional green or blue (silicate-based) and extended life red/orange or yellow (OAT/HOAT) 50-50 mix coolant.
Do I need to drain my cooling system after using Liquid Copper™?
No, this product is designed to be left in the cooling system to protect from future leaks.
How does this type of product work?
It stops leaks by forming a physical plug with organic and synthetic fibers, copper and an ionic modified mineral. The plug forms as the coolant and sealer flow out of the leak. A wetting agent cleans the sides of the hole and prepares the surface for bonding. The first fibers catch on the side of the leak or hole eventually bridging the entire hole. The fibers now act as a sieve trapping more fibers, copper particles and minerals, creating a composite plug. This plug is stabilized or cemented with a liquid glass. The liquid glass hardens with increased temperature and completes the seal.
How long does it take to see results?
Results should be noticeable within 20 to 30 minutes. If the leak is not sealed in 30 minutes of running, mechanical repair may be needed.
What are the dosage recommendations?
Use 1 (one) bottle for regular size cooling systems, this covers most 4, 6, 8 and 10 cylinder engines. For small cooling systems, such as 4 cylinders with no air conditioning, use 1⁄2 (half) of bottle. For other small systems use approximately 3 ounces per gallon of cooling capacity. In larger systems, use 1 (one) bottle for every 6 gallons of cooling system capacity.
MADE IN USA.
WHATSAPP: 012-9154001
Part Number: 1109
FAQ
MADE IN USA.
