B16A Max Modifications
akuma
3,489
152
Kuantan
me no investigator..actually me like 2 share...d truth is,all those mentioned specs r actually frm me engine...only i malu wanna say its mine..miiahahhaahahah
shiroitenshi
3,676
170
Sorry newbie here tumpang lalu..
Of course B16a/b can rev high with less vibration,friction,sidewall-load to the cylinders due to their rs ratio and less rod-angles(1.74:1 & 1.84:1) while b20B/Z and B18A/B (on their standard stroke) are only 1.54:1 and was built by the manufacturer without vtec. 1.75:1 is considered 'ideal' by some engine builders and some of them do believe if below 1.61:1 (with the exception of stock B18C & B18C-R with rs ratio of 1.58:1) , the use of good n strong conrods,bearings,headbolts are recommended.
I dont think u will 'miss' the excitement of b16a's high revving when u plonk in a B20/18's bottom end. Technically speaking, at 7krpm B16A's 81mm piston only travels 18m/sec while B20 with vtec head already reaches 20-22m/sec (depends on it's strokes,piston diameters,bottom end internal weights etc).
If you're afraid of vibrations during high rpm when using above 85mm maybe you can afford an Endyn rods to hold the cylinders if resleeving and blockguard isnt your option.
As for camshaft ,valvetrains,piston diameters,piston selections, static & dynamic compressions,wrist pin locations,a/f ratios tuning,ignitions,fuellings,ITB goes , many SIFUS here including you yourself had discussed earlier.
But if u're planning to only use the stock 137mm rods and headbolts and stock camshaft (?) maybe b20s sifus can help u to choose a relevant piston and their sizes and it's redline range for your wallet-safety purpose.The risk is always there, if Kaboom just build another...even F1 engine 'kong' sumtimes.
Pls correct me if im wrong..peace.
RALAT ITU NORMAL.
sacrifice oil consumption
Actually you're right.. and I don't think I want to argue with you on that.
Actually the B20B is nicer, don't even need high revs to get power.. but the thing with high revs is to achieve the big hp number.. you won't see any other NA engine making 230-260atw with something just a little over 2L.. but honda manages it just fine.. just by making it rev higher, reliably. A 2L b-series built by endyn manages near 300hp at the wheels.. and it only manages to get that with high RPM.. I don't think it's possible to hit the current hp numbers we commonly see on B20B blocks if we're only limited to 6.5K rpm.
Well.. target is a target.. achievable or not, that one another story.
pencalat
805
19
JB
Then 2l max revv is about 8k larr eh??
patut la cepat pow mine...
shiroitenshi
3,676
170
Hahah... football freak ah?
I actually just woke up.. sleep too early just now.. :P
feDex
156
u can try this tips
B18C block
2.0 stroker kit
81.25mm civic type-r piston
Hi all sifus out there,
Currently im considering to buy a crz.. but this car previously was a demo car (according to the salesman) not sure wad demo is it hehe.. so tis car already comes with turbocharged and supercharged.. driven less than 10000km and its selling ard 78k (hvt confirm yet).
i quite like tis car as the price is reasonable to me and would like to try turbo car hehe..the dealer also agreed to let me bring tis car check by any car workshop.
My concern is im not sure...
