B16a Gearbox Synchro Problem
b-eater
148
My b16a gearbox got problem when shifting on gear 3 and gear 5, it is hard to shift gear when high reving that will cos a trouble for me when dragging :Not_Impressed:
Can i know what are the things that need to fix and change and what are the cost of it? Dont as me to change to CTR / ITR gearbox cos i dun have money :X-:
b-eater
148
but i think mine can consider teruk already, change gerabox oil also i think no use wan.
ok how about syncro?? if mine kena gear 3 and 5 what are the syncro that need to be change? can rojak my gearbox to close ratio ah?
b-eater
148
avantasia said:
from wat gear?
3 to 4 or 4 to 5?
mine one from 2 to 3
and
4 to 5.
what are things to repair and what cost?
budin99
429
somebody quote me last time..to repair regarding dis syncro about RM7++.
b-eater
148
i change the gearbox oil to motul last time but still got the problem.
and i think it becoming worst, to pevent it before my gearbox truly koyak i think the syncro need to be change.
but can we rojak the gearbox to close ratio or do i need to change the syncro?
the syncro selling alone in a set by gear or what?
as i surf the N1 website they selling like this:
https://secure.n1racing.net/eshop/index.php?pg=list&prod_id=44
but this one is teribly out of my budget, any choice left??
user6
341
Kuching/Sarawak
Bro b ... ..I got tat kinda problem oso last time..Serviced it once,and it was ok.Few months later the same problem came back..So finally managed to save some money and changed the g/box tat cost me 2k w/out LSD..
In my case,my mechanic told me tat the shaft inside the g/box itself maybe `rosak` so I tought,its been more than 6 yrs so its about time change it...so there goes my g/box problem and my 2k .....ehehiehihei.Worth it?I guess so...
Cheers!
b-eater
148
avantasia said:
syncro is different with ratio!!!!
u change u'r syncro 1st then ratio + using motul gear competition at RM126 per litre....
ohh i tot syncro is the same thing as the gear of the ratio, damn im truly confusing. so the syncro is working by itself la nothing to do with the ratio is it? hermmm.
b-eater
148
Cheers!
yaaa i heard that too, got some do the syncro but in a time the problem will occur back. but it take timela. but if i change the whole gearbox pun ... if the gearbox also got this kind of problem it is the same thing also.
Hi All,
Anyone here have experience different reading when dynoing with different gear(example 3rd or 4th or 5th) on a Dynojet?
Knowing that dynojet utilizing fix mass and how fast(time) to accelerate the dyno roller,so I was thinking if we were to use lower gear,examples 3rd gear ,we may have better acceleration/shorter timer compare to dyno with 4th or 5th due to shorter gear ratio which may lead to higher whp reading?
I heard some tuner will use gear with gear ratio near to 1,but...
