- Dec 10, 2008
- 195
- 75
- 1,528
Hi guys I got a question. A32 manual says to check ATF with engine on. So here is the question. Cold engine start and check ATF on the cold range, the level shown is LOW. When heated up then check on the hot level the ATF level is HIGH as the fluid expands when its hot.
So if you fill ATF to MID or HIGH level on the cold range, when the ATF is hot it is over the HOT range which means overfill.
So which is the best level to fill at?
