Hi all,
I bought a 2nd hand toyota altis 1.6E manual (2003) 4 months ago. The car's noisier compared to my previous iswara. It revs up to 3.6k for 110km/h. I brought it to workshop and the mechanic said that the ECU and firing is fine. He suspects it's maybe due to clutch plate and advice me to change the clutch plate. Does clutch plate could give such problem? Is it normal for car to rev up to 3.3k for 100km/h. I'm newbie and i have no idea on this
All the sifus please help and advice. I don't want to change the clutch plate and the problem still persists.
Sorry bro, I didn't have a Altis before. But i do faced the noisy which are almost same symptom as you face now, and I hope it will help you a little bit.
1st symptom that i found before:
That time is i drive Kancil but with Mira engine with LSD speed gear, when shifted to 5th gear the noise are very similar with the Bus express sound, but I still didn't care of it. 6 month later, i found out every gear are noise already. Then I send it to foremen to check, he said is gear oil need to change. So i go to change to Toyota LSD oil, and the sound was reduced (but not totally no noise)... 1 month later the noise seem coming back again. Then I think it might be something problem the speed gear already, send it foremen again. He said the LSD was KO already, so I asked him to take off the LSD and replace with normal. After done repair, the noise still remain and I already fetch up with keep replacing matter, so i decide to buy another set Kancil speed gear... After that, the noise are no more, even 1 month later I asked foremen to install back the LSD on Kancil speed gear, also no face any noise.
How to identify is speed gear (gear faulty) is when at normal speed that you might heard the noise, try to press down the clutch and keep the throttle in that rpm too. See it still have that problem or not.
2nd symptom that i found before:
That time i was driving LE with 4AGE, i do heard it a lot of noise was coming in the car especially at high rev. I heard it was some sort of like the exhaust sound, was coming in. I send the car to exhaust some and do check for me. They found the piping exhaust there got 1 hole (mean pecah). After they weld back, no this problem already.
Bump:
bro..
a simple guide to check your clutch, drive at 40-45km/h, in second gear, then use left foot to slight press the brake, and at the same time right foot press the accelerator, see if the rev goes up.. try few time to confirm, this is to check for clutch slip
if the rev goes up when u step and brake and the throttle.. then ur clutch need replacement already, if the rev goes down when you step on the brake, that mean ur clutch is still ok.
remember to do this in a empty road, left foot braking need some sensitivity training.. hehehe...juz press slightly for the speed to drop, not to brake..
got this from a troubleshooting manual.. hope it helps
bro, this method i do heard it before, and i do tried before too. All failed le.
1st time test,
The rpm can still increase, and the car move more fast. Seem like brake failure
2nd time test,
Same symptom as 1st time
3rd try,
engine stall
During the time i test, I was with Exerdy flywheel and TRD clutch and TRD cover (all brand new). Is that mean my clutch slip?
