A33 & A32 engine(vq20de), are they the same?
myride
Hi guys,
I need some advice frm sifu out there, I need to swap engine on my A33 (2.0), and i want it the same engine as b4. I manage to find a vq20de engine but it is for A32. My question is, are there any difference between both engine? FYI, my existing engine is almost useless. Oil pump fail, affectting crankshaft, bearing, conrod, pistn ring, etc... So upset, pls help, tq.
tms97
28
1,503
Malaysia
There are "almost" identical but if not mistaken the 2.0 in a32 has loawer torque and horsepower than the 2.0 in a33
myride
Thanks guys, but what should I do? Anybody knows where to find A33(vq20) engine? tried few chop shop, only a32 engine available.
tms97
28
1,503
Malaysia
I havent seen myself but a mechanic told me around batu caves area got a lot of half cut a33
myride
I found a33 vq20 engine, but all neo, the guy at the chopshop said it can be use but without neo(valve lifting function). Anybody know about vq20 neo engine? Without neo function, is the engine still have enough power?
seizai
937
ppl put neo for power, u dun want neo, thats funny :hmmmm:
onionbay
47
try chop shop around Segambut. I've seens a few A33 front portion around.
myride
Its not that I don want neo, to put neo, I might need to buy half cut, I just wanna a simple swap (block&head only...looking for enjin lantai). Also budget is limited. But all chopshop only have vq20neo. They said all imported vq20 engine from Japan is Neo.
wah
120
6
Jalan Kapar got alot of vq20 without neo mar. try lepak lepak n c for urself.
seizai
937
u need get a very very very exp guy to swap those parts
otherwise...
u will facing leaking nightmare
alloy part is a lot diff from steel part like mitsu one
wah
120
6
Even VQ20 for A32 have different cabling set, I found it when I replace my previous VQ20, end up I need to put in a half cut ratter than just an engine kosong, different socket and cable, even ECU connector. Current manual it just missing the auto controller other just same.
Cheer.
Late last year, thanks to Zerotohundred and Shell Helix, I had the opportunity to travel along with the Blue Jackets Fraternitas in two separate drives; down south to Johor, and another up north to Penang. This was in conjunction with the Shell Helix 2011 Invasion Tour, and since the journey included a nights stay at each location, let’s...
