A33 engine jerk problem
Mar 30, 2018
56
Dear Sifu, for the past 2 years having this intermittent issue. any mechanic very familiar with this Cefiro A33 model please recommend. I sent for many places already, but still no 1 can solve. Some TCM change throtle body, still same, changed 2 plug coils after few months problem come back.
Engine jerk can be from many types of issues, Cannot just generalized the problem, and worse is your in intermittent.....
Nightstalker1993
267
130
1,543
Subang Jaya
Intermittent could even be faulty wiring, barely touching etc. Crank sensor, cam sensor, coil trigger wire, even o2 sensor faulty also might cause jerky... I would suggest you change another mechanic, depending on your location maybe someone can recommend a reputable mechanic around your area
sb3
1,141
14
5,138
Hi there. Through my experience for this particular engine, if one coil is faulty , we need to change all of the 6 coils. Otherwise the jerk problem will reoccur . So far nobody can give me a good reason for that. Even asked a few Nissan techie last time.
Dear all sifu,....
i had few question to ask...
My project are bot on turbo to 4g93 sohc engine...
I had whole set turbo kit wif 390cc...
And it was low compression piston already...
My question are....
Can my original 4g93 sohc ecu and air fuel change to 4g63 ecu and air fuel?
Witout change wiring... I mean juz plug and play ecu and air fuel...
Or changing it to gsr ecu and air fuel... Witouut wiring?
Coz i dunwan buy piggyback...
Beside...i can get ecu and airfuel...
