What can be done to make this engine more powerful since external turbos cant be installed . Comments plz :)
hiye . done 3 hours ago . lol . installed HKS air filter . rm200++ . thinking of changing plug cable too . that works too right ? btw , anything other than those ?boosook said:hi there..maybe u can go for port&polish, change air filter..
Bro...kenshins said:hiye . done 3 hours ago . lol . installed HKS air filter . rm200++ . thinking of changing plug cable too . that works too right ? btw , anything other than those ?
Sure . Will do bro . Thanks & cheers :)CARENT said:Bro...
Well come to the club...
I am also driving a 4G93P DOHC. So, I would recommend that u do a PnP. Wanna nego together?
Can sms me at 017 8889518
I hav almost maxed out the mods except for a high cam and PnP. Others all done.
Cables, can get the Hurricane ones will do. But if u hav the budget, then NGK loh....
Plugs, can try BRISK.
not a bad idea though . coz i heard my fren also did the same .Yong_5290 said:use 4g92 high compression piston
change 2 GSR intake manifold n bore match 2 Mivec throttle body...
hi cam...262 o 272 u like....
adjustable cam pulley...
adjustable fuel regulator...
alluminium crank pulley...
rechip ecu
u sure or not ? so cheap ? my fren kena around 4k la fren . if i plan to convert into 4g93t its around 6k . so i might as well convert , right ? anyway , just a survey . no sweat :) thanks anyway bro .Yong_5290 said:wah...this 1 cheap cheap onli wor...gsr 4g93t where got so cheap
use 4g92 high compression piston...chop shop can get like rm 200+
change 2 GSR intake manifold n bore match 2 Mivec throttle body...rm 300+
hi cam...262 o 272 u like....rm 600+
adjustable cam pulley...rm 300+
adjustable fuel regulator...rm 150+
alluminium crank pulley...rm 200+
rechip ecu...rm 500+
then if u dun wan 2 play tat much...dont think of port n polish also...bcoz its gonna cost u over rm 1k...
4g93kenshins said:u sure or not ? so cheap ? my fren kena around 4k la fren . if i plan to convert into 4g93t its around 6k . so i might as well convert , right ? anyway , just a survey . no sweat :) thanks anyway bro .
What high compression piston cost RM200?Yong_5290 said:wah...this 1 cheap cheap onli wor...gsr 4g93t where got so cheap
noted. thanks :)white_bird said:agree wit yong.. alot of hidden cost u wouldnt know 1.. sometimes really tht badluck.. this n tht part cant use.. hav to spend some more.. especially for turbo car.. i xperienced tht.. really hav to backup lot money... unless ur father print note la.. :P kekeke..
Erm.. what do you mean external turbos can't be installed? I thought you could 'bolt on turbo' on a 4g93p?kenshins said:What can be done to make this engine more powerful since external turbos cant be installed . Comments plz :)
Hi Zakie is that Nology Hot Wire? I'm actually looking for it, can tell me where to find?zakie said:haaaa turbos....
use the NOLOGY cable plug....
tahan lama & give more power....
confirm......
