M mmn81 Sep 26, 2013 3 0 501 Denmark Sep 26, 2013 #1 Hello folks I was wondering, if 4G93 SOHC hi comp pistons would fit on a 4G93 DOHC? They have the same piston diameter (81mm) and stroke length (89mm) --- mmn81
GEFORCEXTREME Known Member Senior Member Nov 18, 2009 151 13 1,518 Kuala Lumpur Sep 26, 2013 #2 Can, no problem, it's done here a lot.
M mmn81 Thread starter Sep 26, 2013 3 0 501 Denmark Sep 26, 2013 #3 Hey GEFORCEXTREME Thanks for the answer :) Good day to you! :wavey: ---mmn81
D dking91 Known Member Mar 26, 2013 121 11 518 pekan Sep 26, 2013 #4 mmn81 said: Hello folks I was wondering, if 4G93 SOHC hi comp pistons would fit on a 4G93 DOHC? They have the same piston diameter (81mm) and stroke length (89mm) --- mmn81 Click to expand... why not using 4g92 sohc pistons??
4gbanger 1,500 RPM Jun 26, 2013 1,958 386 683 Johor/ShahAlam Sep 26, 2013 #5 i heard 4g92 has higher comp.. but not sure..
