From a humble beginning in the Late Eighties, 5 Valve Per-Cylinder Four Throttle Yamaha was introduced to the world in the form of a Yamaha FZR1000 EXUP GENESIS. And from there onwards it grew ever potent that it was extended and introduced to 4A-GE linage that we all are very familiar with.
Not known to many, the very same team of engineers that developed this lovely head design was also responsible for Valentino Rossi 2004 YZR-M1 that stormed the circuit with blazing grace and glory - The rest is history. Of course YAMAHA owe this success largely to the godlike talent of Valentino Rossi who himself has become the primary factor for the engine development direction.
Today, once again Valentino took his YZR-M1 to victory. But most importantly the 20V design has been reverted to 16V for a much more predictable power delivery throughout the revs. Nonetheless, 20V Four Throttle still reign supreme with Road Production YZF-R1 and YZF-R7.
YAMAHA YZR-M1 2005
Engine
Engine type: Liquid-cooled, in-line, 4-cylinder, 4-stroke with 16-valve DOHC
Displacement: 990cc
Ignition: Magneti Marelli with adjustable mapping - NGK spark plugs
Carburation: Fuel injection
Lubrication system: Wet sump - Motul Oils
Data recording: 2D
Maximum power: More than 230ps
Maximum speed: Over 330 km/h
Transmission
Type: 6-speed cassette-type gearbox, with alternative gear ratios available
Primary drive: Gear
Clutch: Dry multi-plate slipper clutch
Final drive: Chain - DID
Chassis and running gear
Frame type: Twin-spar aluminium frame, multi-adjustable steering geometry, wheelbase, ride height, with aluminium swingarm
Front suspension: Fully-adjustable Öhlins inverted telescopic forks
Rear suspension: Braced aluminium swingarm with single Öhlins shock and rising-rate linkage
Front/rear wheels: 16.5 inch front, 16.5 inch rear, available in a variety of rim widths
Front/rear tyres: Michelin, 16.5 inch front, 16.5 inch rear, available as slick, intermediate, wet and hand-cut tyres
Front brake: Twin 320mm carbon discs with radial mounted four-piston Brembo calipers
Rear Brake: Single 220mm ventilated stainless steel disc with twin-piston Brembo caliper
Weight: 148kg, in accordance with FIM regulations
Fuel capacity: 22 litres, in accordance with FIM regulations
YAMAHA YZR-M1 2005
Engine
Displacement: 990cc
Data recording: 2D
Transmission
Primary drive: Gear
