midship: is it possible to shave off inner fender cover? last time i asked someone from the paint shop, they said can't215/45 R17 will be a better bet should you plan to slam it to the ground failing which you will have to cut/shave off inner fender cover.
Assuming you are on offset wheels, what is the rear wheel dimension?
