1991 Cefiro A31
1991 Cefiro A31
pink cefi
1,400
Kota Kemuning
Letting go my A31 as i'll be going overseas pretty soon. Would be a waste to have it collecting dust at home after so much effort has gone into it hence it'll be a much better option having it in a new owner's hands. Specs as below
Make: Nissan
Model: Cefiro A31
Year of manufacture: 1991
Mileage: Unknown
Color: Matte Dark Grey
Condition:
- Exterior wise its definitely not in its best shape as it requires a new set of bodykit (Can work out a deal here)
- Engine is in top notch condition (Serviced after every 1 or 2 events)
- For mods please refer to list below
Price: RM67000 nego
Contact number: +60166299159
Mod List
-Engine-
R33 RB25det
Garrett BB GT35R .63 Turbine Housing*
Tonnka Top Mount Header*
Tial 44mm External Wastegate*
Sard Racing BOV*
Greddy 4" Massive Intercooler
Custom S/S 2.5" Cold Side 3" Hot Side I/C Piping*
Isis Greddy Style Intake Plenum*
80mm Throttle Body*
Mace Engineering Thermal Insulator Intake Manifold Gasket*
Tomei 1.2mm Metal Head Gasket*
Tomei 260' 10.25mm Camshaft
Japan Custom Adjustable Cam Pulley
Splitfire Coilpacks*
Brisk Racing Plugs #8*
Pitworks Timing Belt*
K&N 6" Air Filter w/ Custom Air Ram*
Greddy Oil Catch Tank*
Full 3" Exhaust Piping w/ Apexi N1 Muffler & Centre Bullet
Samco Hoses & Joints All Around*
-Fueling-
ATL 30L Fuel Saver Cell
4L Fuel Surge Tank*
Walbro 255lph GSS342 In-Tank Fuel Pump*
Walbro 255lph GSL392 External Fuel Pump x2*
Greddy Fuel Rail*
Fuel Injector Clinic 750cc Top Feed Low Impedance Injectors*
Fuelab 515 Series Fuel Pressure Regulator*
Aeroquip S/S Braided Fuel Hoses w/ Duratech AN Fittings*
-Drivetrain-
RB20det Trans
Nismo Supercoppermix
Cusco Type MZ 2 Way LSD
Custom PU Trans Mount*
S/S Braided Clutch Line*
-Cooling-
Forged Racing Aluminium Radiator*
NTCL 68'C Thermostat*
Samco Radiator Hose*
Custom Reservoir Tank*
Pivot 1.3 Bar Radiator Cap*
RB26 Clutch Fan
Zap Oil Cooler Kit w/ Oil Filter Relocator*
Mishimoto Power Steering Fluid Cooler*
-Brakes-
Double Layer Brake Servo
GTS33 4Pot Caliper (Front)
GTS32 2Pot Caliper (Rear)
Endless SSS 0-500'C Brake Pads (Front)*
Endless VN9500 0-300'C Brake Pads (Rear)*
Custom Hydraulic Handbrake w/ Wilwood .625 Master Cylinder*
All Around S/S Braided Brake Hoses*
-Oils & Lubes-
Motul 15w50 300V Competition Engine Oil*
Torco 75w90 SGO Transmission Fluid*
Torco 75w140 SGO Differential Fluid*
Bosch Dot 4 Brake*
Motul RBF600 Clutch Fluid*
-Chassis & Handling-
Custom Full Welded Roll Cage*
Full Chassis Spot Weld*
Undercarriage Chassis Foam*
KTS SC β Hi Lo Soft Hard Adj Coilovers*
Powered By Max Super Angle Kit*
Megan Racing Front Adj Lower Control Arms*
Megan Racing Front Tie Rod & Tie Rod End*
Megan Racing Rear Adjustable Lower Arm*
Megan Racing Rear Adjustable Toe Rod*
Megan Racing Rear Adjustable Traction Rod*
Megan Racing Front & Rear ARB End Links*
Cusco Rear Upper Camber Arm*
Ultra Racing 2pt Front Strut Bar*
Ultra Racing 4pt Rear Bar*
Ultra Racing 25mm Rear ARB*
Custom Front Wheel Tubs*
Custom PU Bushings All Around*
Flattened Boot Well*
-Exterior-
Wonders Replica Body Kit (pretty beaten up and missing a right side skirt)*
Custom Metal Wide Arches*
OMP Bonnet Pins*
SRR Silicone Trunk Hood Lock*
Custom Front & Rear Tow Hook*
-Interior & Electronics-
HKS FCon Vpro
Greddy Profec B Spec II*
Pivot Tacho w/ Shift Light
Defi Racer Gauge Boost Meter
Defi Racer Gauge Water Temp Meter
Defi Racer Gauge Oil Temp Meter
Drift Performance Oil Pressure Meter
OMP Cut Off Switch*
Custom Carbon Fibre Switch Plate*
Battery Relocated To Rear Off Passenger Seat (AC Delco NS60 w/ Tonnka Battery Box)*
Lightened Wiring Loom w/ Full Wire Tuck
Custom Relay & Fuse Box*
Fully Gutted Interior
Lexan Windows*
Custom Alloy Door Panels Wrapped In Black Material*
Schroth Profi-III 5 FIA Approved 3" 5pt Safety Harness*
OMP TRS Plus FIA Approved Full Bucket Seat*
Bride Brix Semi Bucket Seat
Greddy 2" 4pt Safety Harness
Momo Drifting Steering Wheel*
Momo Race Evo Shift Knob*
Custom Alloy Plate To Close Boot From Cockpit*
Detmar 4" Cooling Fan*
-Wheels & Tyres-
Rota Boost 17" 9.5J et+12*
Work Emotion 11R 17" 9j et+17*
245/45/17 Dunlop Direzza Z1 Star Spec (Front)*
235/45/17 Achilles ATR Sport (Rear)*
25mm Wheel Spacer All Around*
Blox AL7075 Alu Lug Nut (Front)*
JS Racing Chromoly Lug Nut (Rear)*
-Items indicated with an asterisk (*) are both brand new
-All spares that I have will be given to new owner as well like trimmed to fit rear seats, a/c parts and other small bits and bobs.
-Apart from the beaten up bodykit, car is in mint cond and taken care off very well (Take note, shell is in mint condition, only bodykit is beaten up.)
-Car still has a live road tax, so its not necessarily a full time dedicated track car
-Might have missed out some important details bout the car so sorry if anything looks like its suppose to be there but isn't.
-Pictures-
When the car was all in order
Current condition (no proper pics at the moment)
Engine Bay
Interior (note that handbrake lever is currently the longer one)
Fueling
Footwork (Don't bother the exhaust, piping has been replaced with a new pipe)
Contact me @ 0166299159 (sms if call not answered, will reply or call you back) or pm if interested.
More info or pic upon request.
Low ballers or bad mouthers, leave all the useless comments to yourself.
pink cefi
1,400
Kota Kemuning
@ColdPlay
Thanks dude. By the way, that pic was taken few months back when the assymetric was fitted temporarily to get the car moving. Running 245/40/17 Z1 Starspec for the front now. Like i mentioned at the pic description as well, exhaust also redone already :D
@dangerousboy12
Alvin? Yupp, have to sell it off since going overseas soon. If not nobody's gonna be taking care of the car for me at home
pink cefi
1,400
Kota Kemuning
Am open to offer (don't give a real ridiculous offer though) as car have to go as I'll be leaving the country pretty soon :D
AD_EG
6,000 RPM
6,328
231
Ipoh
niceeeeeeeeeeeeeeeeeee! bump for a monster
