[font=arial, helvetica]1986 Lamborghini LM002[/font]
price = $65 000 usd
engine = V12valvetrain = DOHC 4 Valves / Cyl
displacement = 5167 cc / 315.3 cu in
bore = 85.5 mm / 3.37 in
stroke = 75 mm / 2.95 in
compression = 9.5:1
power = 335.6 kw / 450.0 bhp @ 6800 rpm
hp per litre = 87.09 bhp per litrebhp/weight
torque = 500.3 nm / 369.0 ft lbs @ 4500 rpm
drive wheels = Front Engine / 4WD
body / frame = Aluminium & PFibreglass Panels
front brakes = Vented Discs
front wheels = F 43.2 x 27.9 cm / 17.0 x 11.0 in
rear wheels = R 43.2 x 27.9 cm / 17.0 x 11.0 in
front tire size = 325/65VR-17
rear tire size = 325/65VR-17
steering = Recirculating Ball w/Power Assist
weight = 2700 kg / 5952 lbs
wheelbase = 3000 mm / 118.1 in
front track = 1615 mm / 63.6 in
rear track = 1615 mm / 63.6 in
length = 4900 mm / 192.9 in
width = 2000 mm / 78.7 in
height1850 mm / 72.8 in
transmission = 5-Speed Manual
gear ratios = 2.99:1, 1.90:1, 1.33:1, 1.00:1, 0.89:1
final drive = 4.125:1
top speed = 210 kph / 130.5 mph
0 - 60 mph = 7.7 seconds
