Aftermarket HID: they may help you see better but they are blinding the %#$ out of me
7,514
Re: Aftermarket HID: they may help you see better but they are blinding the %#$ out o
here is the example of good projector fitted....(i use the smallest type for both)
low beam (with beam cut-out shield in place)
high beam (with beam cut-out shield removed)
*notice the differences in beam glare???so...even if install HID no glaring to other traffic...problem setel...owner happy,other road user happy... :adore:
arturo
nooB
2,722
1,083
SateCelupLand
Pomen...wat u use as shroud? i pening trying to look for something big enough to shroud my projectors...worse come to worse, spray whole inside reflector flat black n hope nobody notices hehehhe
7,514
your projector doesn't come with glare shield ah????
then fabricate with steel plate would do the job...secure by 2tonne glue or screw either way oso can....but must measure and cut properly....
arturo
nooB
2,722
1,083
SateCelupLand
got glare shield. mine is bixenon. i just dunno wat to use to cover the projector inside the headlamp enclosure. some ppl call bezel...some ppl call shroud. so far i think i need to use pvc pipe reducer to get it to fit...
7,514
ok2 i get it...like "traffic light shroud" rite????
just use pvc pipe ok....i didnt cover it....just spray everything to flat black or leave it as it be.....(use smoked headlight cover oso can help) :driver:
arturo
nooB
2,722
1,083
SateCelupLand
thats y loh...thinking if after mount n align still no shroud, just spray flat black n cover back. maybe get tin milo n ketuk so can fit? heheheh. u use what sort of glue to fix? or use L bracket?
7,514
well...2tonne glue do the job nicely....(get a quality brand like bostik and jbweld) ..not cap ayam brand
i rarely use bracket because of space constrain.... :adore:
7,514
Reporting to you live from Tokyo (if a 2 hour delay is accepted). We made an exclusive trip to Top Secret Japan. There was a intimidating feeling of an underground joint as we pull up at the venue in Chiba lead by non other than Nezuka-San from Duke Racing Japan...
