My car is from NA to turbo.
Was installed with BOV.
I don't like to whisper sound, so can it be done from BOV to CBV?
CBV=Compressor Bypass ValveCBV?..u mean recirculate?..sure u can..
There are tons of dump valve that's able to recirculate. SSQV has a recirculation kit. But it's hardly found in Malaysia. But I've posted somewhere sometime ago on the drawing/dimension of the recirculation adapter if anyone would wanna to fabricate it from a machine shop.I find that car with MAF using recirculating route tends to drive much better in terms on engine performance.Definitely able to but will you be able to get an adapter for your BOV that you are currently using?I think SSQV has a recirculating kit and as i know sheepdog BOV does have the recirculating madel as well.But a sheepdog BOV with a recirculating route couple with an open pod filter does produce those fluttering sound.
Well, the compressor surge happens when the throttle closes and the dump valve is not opening. As a result, the compressed air has no where to go but to reverse the flow direction and flow back to the compressor.S2H,the funny thing is another sheepdog BOV that was fitted into an evo also produces the fluttering sound which i know ppl say is compressor surge.So meaning compressor surge is bad for the engine and the thing is when the sheepdog is not fitted into the recirculating inlet i can see that the BOV is working but why does it produces this sound?
When u talk about reroute, it goes to the suction/intake. But when u uses standalone, u're converting from MAF to MAP sensor. So, blowing off is fine because the injectors react directly refering to the manifold absolute pressure. So, no problem with stalling engines and air starvation. Provided u want to silent ur car...if i'm using standalone, where do i route the excess air? to the compresor suction pipe?
Once upon a time, S2H has an order of EVO IC piping from a customer from Nilai. However, S2H does not provide COD outside of Klang Valley. Somehow, buyer offered UPAH HANTAR than S2H can never refuse... RM2++ just to deliver from KL to Nilai.. Calculating the cost that involved in sending the stuff, S2H agreed to send.S2H, sometime i feel annoy with the blow off sound so plan to redirect it into system...maybe bored with sqv whistle
Same story like mine had few month ago....Once upon a time, S2H has an order of EVO IC piping from a customer from Nilai. However, S2H does not provide COD outside of Klang Valley. Somehow, buyer offered UPAH HANTAR than S2H can never refuse... RM2++ just to deliver from KL to Nilai.. Calculating the cost that involved in sending the stuff, S2H agreed to send.
On the next day, S2H happily driving his car into the NS Highway with his newly installed SSQV ORIGINAL... Coming near to a R&R, S2H was highly irritated with the whistle from the SSQV and couldn't stand the high octave NOISE and he finally stop at the R&R to remove the SSQV and replace it with the plastic recirculation valve from stock EVO IC piping. S2H worrying about the way return home which have to bare with the noise again... S2H felt moody all they way till client's place.
When reached the client's place, Client ask why was that SSQV lying in the rear boot and he made an offer to top up some money to swap the plastic CBV. Happily, S2H accept the offer without any negotiation to top up more than offered and there he goes... S2H, driving happily with his quiet car all the way back to KL... Though there are some minor boost leak, but tolerating the boost leak is anyway better than tolerating the whistle....
Thank you for reading. Story was narated from a true story and purely based on personal experience. IF there is any unsatisfation on the statement included in the story, please keep it to yourself and I won;t entertain and care... Hehe....
Right now, I'm using Greddy TYPE S recirculating back into the intake ram... Welcome to the silent killer world...
Hohoho.... Mine was years back... Keke...Same story like mine had few month ago....
Slap 9 the fella whom told U that....heard that CBV will lost low end response?
LOL, the workshop mechanic boss said.Slap 9 the fella whom told U that....
Show me the calculation
rilek taikor, dun angry..heheSlap 9 the fella whom told U that....
What bov u using?LOL, the workshop mechanic boss said.
I don't like BOV, i like silent.
Sian, give $$ to do BOV to CBV also cannot.
Sorry... Turbo cars can use MAF?I find that car with MAF using recirculating route tends to drive much better in terms on engine performance.Definitely able to but will you be able to get an adapter for your BOV that you are currently using?I think SSQV has a recirculating kit and as i know sheepdog BOV does have the recirculating madel as well.But a sheepdog BOV with a recirculating route couple with an open pod filter does produce those fluttering sound.
Example:Sorry... Turbo cars can use MAF?
Hey seriously... I never knew that turbo can use MAF. I thought all turbo must use MAP? This is new... How does the MAF function in turbo car? And why do people and my mech say that if we would to turbo a 4AGE Silvertop, must change the MAF to MAP? They said it is not good for turbo... Please advice...Example:
Mitsubishi 4G93T
Mitsubishi 4G63T
Mitsubishi 6A12TT
Mazda B8 Turbo 180/210
Toyota 1JZ
And the list goes on.
What he was trying to say was, turbocharged car that uses MAF tends to feel better n more responsive when BOV recirculates. And yes it is.
But fluttering sound could be caused by compressor surge.
bump...s2H.. kindly re-post or pm me or email [email protected] a ssqv re-circ kit diagram drawing.. need to fabricate it ..
thanks in advance
Lolz... MAF is a method ur EMS measure the flow in terms of flow volume. MAP, is also a way to measure air consumed by the engine, but in terms of pressure... And both the pressure and flow have direct relation. Just the matter how ur ECU gonna calculate... 1 speaks german, one speaks, chinese.. that's all... But both measuring method also can be used...Hey seriously... I never knew that turbo can use MAF. I thought all turbo must use MAP? This is new... How does the MAF function in turbo car? And why do people and my mech say that if we would to turbo a 4AGE Silvertop, must change the MAF to MAP? They said it is not good for turbo... Please advice...
Sorry a bit off topic...
Sorry, late reply. Here U go... Got it from a friend. But I've not use any SQV...bump...
:hmmmm:
