6a12tt-rs.perdana v6
budakkampungaje
317
Dengkil
bdk kampung,,
u using v6tt manual is it? u could lose the ABS...
mine does not have ABS, there is a saying..'real man dont use ABS' haha.
mine before using auto after that i convert to man.......i already taken out the ABS.......
i want to ask you something my engine have sound like 'SEWING MACHINE' why aaaa.....such i know the prob is using the engine oil....now i'm' using CASTROL MAGNETIC 10w40.....now my planing want to change the engine oil in my mind now is.....
1.TORCO SR1 SEMI
2.IDEMITSU EXTREME PRO FULLY
3.MOTUL..
i want to ask you wich 1 is better for twinturbo....in my mind TORCO......but this oil is toooo expensive....1L RM 65 5L is RM 325.....but for IDEMITSU 1L RM 42 5L RM 210.....sooo wich 1 is better....please HELP....:hmmmm:......:adore:
NeuroOne
WFH
2,074
181
Putrajaya
fuhh.. very mahal le those oils.
why don't u just use normal priced oils? hehe..
if money is no prob for u, try Amsoil or Royal Purple or Shaeffer
kanan
908
52
why not increasing the spring preload in the oil pump by putting 1-2 washers.quite many success stories on this
budakkampungaje
317
Dengkil
yeeeezzzzaaaaa...but what i heard from the TORCO OIL sales manager the TORCO OIL can increase the HP it's about 4hp-8hp....:wink:
Reactions: birdking
mag9556
2,770
43
1,648
me using Kancil engine oil from valvoline... nice to drive but wont last for long..hehe
budakkampungaje
317
Dengkil
i'm having a big problem..my engine has a leaking engine oil at a top....firstly i think is engine oil cap but i repalce the cap but it's still leaking....did you guys know why i still leak...? now i'm suspek the gasket.....
NeuroOne
WFH
2,074
181
Putrajaya
which part of the top leaking?
at the oil cap area?
or between rocker cover and head?
or between head and block?
or on top of rocker cover?
gamba tarak, ko bgtau pon tak jelas..
budakkampungaje
317
Dengkil
the oil is in area V6 DOHC 24 vavle sign beside the engine oil cap....susah laaa nak upload pic kat opis kena block...
NeuroOne
WFH
2,074
181
Putrajaya
if at that area, i can think of nothing other than spark plug seal leaking.
or maybe also the rocker cover.
susah nak agak la bro..
sebab kat atas tu, yg ade lobang cuma spark plug dgn oil cap je.
rocker cover dan head maybe leaking ke tepi.
budakkampungaje
317
Dengkil
that's whyyy aaaa ari tu ada gak cek spark pulg tapi kering jeee.....that oil siap bertakung lagi kat sign tuuu....i think want too put some more rubber at that cap.....if is leaking just get to workshop...
I had some questions here, I heard from most exhaust shop, which tell me auto car must maintain certain level back pressure(flow velocity).
But some says auto tranny need as much back pressure as possible to get the best fc and pick up:hmmmm:??
My current exhaust set up was
4-2-1 - 1.6(piping) - 2.0 inlet straight flow long type muffler - 1.75 straight flow ( hotbits ).
The reason I using straight flow, because when I was asking the open pod method with speedwork, they ask me to do...
