Brake upgrade for 1990 SW20
razmrtwo
50
12
1,508
Hi all, its been a while since I posted here. Anyway, can u guys recommend me what are the recommended brake upgrade for my 1990 SW20 Turbo. Its originally an NA so the brakes are still stock NA and I wanted to upgrade the brakes. Can I use a bigger brakes from other Toyota models like Supra, Aristo or Celica?
iexit
1,874
59
1,648
Selangor
iexit.multiply.com
A simple plug and play option is the 245hp Turbo brake upgrade. Its fits with out mods and its good enough for daily drive and weekend track attack.
You can retro fir supra/laxus/celica brakes in too but that will require quite a bit more time and money.
razmrtwo
50
12
1,508
What is the difference in the sizes of 225hp turbo brakes and the 245bhp turbo brakes? Finding a 245bhp turbo brakes proves to be too difficult since I haven't seen any 245bhp turbo halfcut being bring into Miri, let alone Brunei.. But there are a lots of big brakes from the likes of aristo, chasers, markII though..
fishie
120
hihi all sifussS.. long time never visit here..
anyway.. interested in upgrading brakes... my ride like having difficulty to stop.. but brake pad still cukup according to the workman.. any suggestion?
some said i should upgrade to 4pot or 6pot disk as well.. true? or those called brembo brake.. true?
Sep 22, 2010
2
503
The brakes on the mkII were upgraded from rev1 to rev2, but were the same for NA and turbo. So if you want a bolt-off bolt-on upgrade for a 1990 rev1 car then you can upgrade to the rev2+ brakes. (Hence why the standard alloys went from 14" to 15", to accommodate the larger brakes).
Of course, if you want to adapt another set of calipers to the hubs then the world is your oyster. Just remember the handbrake is cable operated, so some aftermarket calipers will require to to keep the stock rear calipers as well :stupid:
BTW, the rev2 started in December 1991, from chassis number 0059266
Firstly good improvement.......but
the rear crome lining seems ugly
please remove that item so that it can see better
engine? seem there is no improvement from the catalog i read
110hp not good enough to put your body into the back of the seat
common proton when the real campro(cam profile) will be reveal?
Even standard old waja standard engine has no any variable valve system can get 112hp?
Dont be "cam pro" ok lor....
