all 4g93 na owners out there!!!!!!
Jan 30, 2010
2
bro.mine same engine with u.can share some modification more details cos i feel my engine not so powerful.4g93 sohc auto.only can reach 170 max.some more starting not so terangkat.can sifu2 out there give some idea to improve.thanks
kairigi
393
27
www.facebook.com
I think for small but value for money is changing the air filter to a K&N open pod. Mine is the super big one, really sounds nice when you rev and slightly more torque.
For more power, I've been thinking of converting it into a DOHC, by replacing it with the 4G93 DOHC cylinder head. But I realised since the engine is terbalik, the only way to get more from the engine is only these:
1)NA Tune (PNP, Balancing, etc.)
2)Convert to a silvertop MIVEC cylinder head (also terbalik so it fits our engine nicely)
3)BOT
Last but the best possible way : Convert to Evo IV 4G63T.
I actually just got my car and now it's on the way to me across the sea :) I'll see what I can do with it.
kairigi
393
27
www.facebook.com
about >rm2k for 10hp..1.x kgm...izit
hp 4 na r expensive...rite:burnout:
not really la..
header (rm300++) = better torque and response
exhaust piping (rm400++) = same as above
PBECU (rm1k++) = more power, fuel eco and some other stuff
stroker kit (rm2k++) = more power of course, and also the most expensive NA kit
and some others la i dont know hahaha
liz@rd
492
57
errr , that 10whp and 1kg++ was only after emanage
not really la..
header = 580 hotbits
exhaust piping = prev owner did up
emanage = 1.3k
stops here alrdy , no more ... that's all i did
joe_mirage
1,030
44
1,648
rotationperminute.blogspot.com
@liz@rd:
137whp (+/-150hp on crank). thats good enough for an NA engine without variable timing. thumbs up.
4
Hi there,
I have been using a mivec gearbox with full lock lsd and exedy clutch for my sgti 4g93 mivec, i've been having problem shifting gears at high revs, i swap my gear box with one from a 4g92 but put back the lsd, and still hv problem,is it bcoz of the clutch? i bought it brand new for rm980,anybody facing this same problem? help needed!
oly
823
2
3,018
Lumut
Hi there,
sometimes when u hi rev this problem will come...maybe u can change gear at rev 500-1000rpm lower...or pressure plate got problem... :)
liz@rd
492
57
wish i can install a mivec head :(
lolz , i wished too but it was long long time ago ... now no more modifying , maintenance only
whats ur engine spec?..
erm , engine stock to the bone lor , just regular service since my friend bought it , every 4k must change engine oil , then i also every 3.5-4k service ...
@liz@rd:
ok le , but the time will come when u need 2 overhaul it ...
oly
823
2
3,018
Lumut
stock gti engine ka?..yesterday come one gti to our workshop...conrod bearing sudah makan...poor owner...just buy the car 1 month plus oni...lagi timing belt mahu putus...third piston oledi knock head...after dismantle all...need to change crankshaft too...poor owner...the used car shop dont wanna pay...
liz@rd
492
57
stock 97 4g93p , maybe the previous owner alrdy whack the engine kau kau le , or alrdy damaged when he bought the car then whack kau2 somemore = gg
anyway u have workshop ? whereabout ?
kumar22mostwanted
1,562
152
HELL!!!
walau wei this make me dam scared to buy second hand car again :afraid:
so do u guys think it is better to buy from owner direct or second hand car dealers???
coz i always thought second hand dealers more reliable coz they will provide a short warranty period for the car after u buy it although they are pricier
wat do u guys think???
Similar threads   Forum
Mitsubishi Lancer Owners Club
Car Modification
Car Modification
Car Modification
Forced Induction & Engine Management
  Similar Threads
Car Modification
Car Modification
Car Modification
My car is Civic EK3
The problem is got abnormal sound at from arm then
1. At 1st, I changed all ball joint and the noise still same
2. Few months later, I changes upper arm bush and the sound reduced 50%
3. Few months later, I change lower arm bush and the car run steady with new bush but the problem is the noise increased
what will the problem be?it is
1. Absorber??? --->my absorber no leaking or the absorber bush damaged??? --->is this bush sold in market?
2. Absorber shaft...
