campro engine got sound "tek, tek, tek"
andrewleo013
5
Dear all bro,
I'm Andrew here who using proton campro engine. Recently, i have found that my car's engine got one strange sound coming out, sound like "tek, tek, tek" (sound like taxi's engine), after i driving back from other place. But, when i start my car in the early morning (when engine cool), don't have that sound. So any bro know what sound is that??? will cause any problem on my engine??
mkdreamervl
327
32
Sounds like ur tappet... but since u say cold starts doesnt have that sound.... most probably is not, kinda hard to tell with just a "tek tek tek" online bro :)
yeehau86
Feb 10, 2007
2,856
2,425
perhaps if you include a video it will make it clearer.
imhotep
21
1,503
hi there..
the tik-tik sound is about latch sound..
it will become more noisy if u r using thin engine oil..
to prevent from this sound..try to use thicker oil ( suggest to use xW-50 ) grade sae 50 at behind..
this is normal sound from campro when using thin oil
Ratbit
75
15
1,508
errr...my campro using 0w-30 fully synthetic engine oil..since day 1:biggrin:, but there is no "tek, tek, tek" engine sound..have u check your valve timing and cam pulley..maybe is "piston knocking with valve ?..:hmmmm:
imhotep
21
1,503
using thinner oil is good as long as u r not the one who always flooring the pedal..try to run ur car and maintain high speed in long journey..then u will know what i said..0/30w is good for town driving..but not for our campro when talking about hard hot driving.. pls dont push ur engine frequently..
me always north south every month..ever try 0w/30..but the latch sound become more worse..then changed to fully eneos 5w/50..it's the best afford oil i ever used...smooth like a hell...MOTUL..? ya it's a syioq oil..but when looking at the price..its really scaring me :adore:
yeehau86
Feb 10, 2007
2,856
2,425
so what you mean is switch to semi synthetic rather than fully synthetic?
EvolutionZ
5,000 RPM
5,027
1,448
intake manifold sometimes causes this tek tek tek sound.
anyway go to SC and check it out....its under warranty.
noriezmen
11
Bro,
If your Campro is IAFM version. I have the answer. The tek3x sound is from your IAFM module. Its actually the sound of IAFM valve veedle. These valve acts such as VTEC which will open and shorten the air flow into the piston when your RPM at 3k (or 4k, i cant remember). For non IAFM Campro, they do not have this sound. The IAFM actually eliminates the torque dip which is well known for old Campro engines.
fatality69
20
4
1,503
Kch/Swk
Bro,
Your replies.... yes and no.
Yes - If TS's campro is IAFM version, then yes... it is indeed the IAFM problem.
No - common la...its totally not like vtec at all. not even close! . hehehe... i wish :P. It's basically an integrated intake manifold incorporating two intake runners of different lengths operated by vacuum solenoids / valves. Long runner length intake will be used for low rpm range (till 3.5k / 4.8k rpm if not mistaken) before it switches automatically to short runners. Reasons are to fine tune the air fuel mixture and etc to "solve" the torque dip that naturally comes with all Campro engines except cps versions.
CPS campros also have this "IAFM" version of theirs but its more advanced and is completely controlled by the ECU. Operating range for the short and long runners are different.
TS - I had mine (IAFM) replaced at 4k KM. It was manufacturing defects whereby the internal valve needle had some clearance issues causing it to come into contact with part of the module. Some SC actually took it apart and "mod" it a bit and it works just as good. But some just claim new set for the owner. Mine was changed completely. I was advised before hand though that eventhough its the improved version... If listened and observed very closely (ears near the IAFM)... it still does emit a very SLIGHT noise which they admit is normal and not a problem like before anymore.
It's been over 10k KM with the warranty replaced IAFM and there was no problems ever since.
singchaii
687
Pandan Jaya, KL
What fatality69's said is true.. The sound is from the IAFM valve needle. If fed up with the problem, you can convert. I had convert most of the iafm sound problem..
For CPS, it had also IAFM.. But this device more advance compare with campro version. That why it called it VIM...
BlackRS125
andrewleo013, does it happen somewhere around 1600 - 1900 RPM? My car engine got knocking problem and it happens only in that range of RPM.
veldric
235
are u using campro IAFM??? if yes...then most probably its ur IAFM........it hapent t ome before and i've changed it for 3 times...hope this helps.
Dear all bro,
The Marketplace Top Posts
There's may be a bit cheesy to some, but when your bringing a date out, look no further to bringing her in an Acura TSX (Otherwise known as the Honda Accord Euro, outside of it's American market) With gadgets such like voice navigation, onboard weather info, Ipod connectability and so forth, girls, especially that they are not geeks would totally be impressed. Check out the video on the Acura TSX, a luxury...
