Absorber top mount ka? what components it will comes together with? What is the reference price?absorber top mount loh. it come complete. Also ask for the rubber seal.
"mounting insulator and rubber parts"?I bring my A33 to TKA in nibong tebal last saturday. The person in charge Dennis told me that the "bump stop" on top of the absorber wear already. And the absorber no problem. Just replace the "bump stop". This wear causes a clog clog noise when go over bumps. All nissan has the same problem woh... So he ask me to go get the parts for him to replace.
I search bump stop from unker google and it turns out another thing. So I am not sure if i were to mail order from PH auto, they will send me the correct items.
After searching for the parts assembly, found that there are so many parts sandwich in between. And NONE of them name BUMP STOP.
confuse with that 2 oil... never change clutch oil b4Are you referring to hydraulic clutch? that one only if you are driving manual mah. is same as brake oil...is difference oil with g.oil.
And BTW, use the Nissan D-Matic, is still the best for Nissan box.
Gear oil?Oil stain feel bit greasy, no burn smell like engine oil. Wonder what oil is that...
Seizai, you need to go underneath your car , take out the rubber insert at the gear box and dip your finger inside the hole. if your finger is filled with gear oil , then no need to top up loh. BTW, dont use Nissan matic g/box oil as you are using manual transmission and oh, your g/box oil will not have burning smell even how hard you trash it. Only AT have burning smell. (Unless you have changed to AT)how to check gear oil level?
A32 got manual trans model meh?
wow... need to climd in againSeizai, you need to go underneath your car , take out the rubber insert at the gear box and dip your finger inside the hole. if your finger is filled with gear oil , then no need to top up loh. BTW, dont use Nissan matic g/box oil as you are using manual transmission and oh, your g/box oil will not have burning smell even how hard you trash it. Only AT have burning smell. (Unless you have changed to AT)
bro check ur power sterling oil , any leak? If not maybe from joint flywheel area to gearbOx.jus snap some pic
Aiyah, our fatty tends to leak oil all over the engine due to ageing leh. just make sure you check all the oils regularly and wash off the oil with engine de-greaser. Will save you money and time. Don't worry, the engine will not breakdown due to oil leak.
---------- Post added at 01:41 AM ---------- 6 hour anti-bump limit - Previous post was at 01:32 AM ----------
i oledi wash part of stain...Aiyah, our fatty tends to leak oil all over the engine due to ageing leh. just make sure you check all the oils regularly and wash off the oil with engine de-greaser. Will save you money and time. Don't worry, the engine will not breakdown due to oil leak.
For anyone embarking on a budget sim rig journey considering using a cheap / spare TV instead of computer monitor, this is what I gathered from my recent sim racing experience, comparing my existing 55″ 1080 TV setup to a computer monitor.
While the expansive TV screen offered immersive visuals, the computer monitor brought forth a sharper focus on details and a faster response...
