something wrong??
drewn123
220
HI there... :itsme:
I wanna ask something that i realised when i'm cruising down the highway. I'm using EK with b16b with stock gearbox.
My problem is this, i drove around 1hr plus on the highway using 5th gear and constantly around 110-130km/hr.
So when i drive into a R&R for breaks. I realised that my gearbox is a bit heavy. i.e. shifting down to 4th or 3rd would be heavier than normal.
So my question is.... is it normal?? or a symptom to a greater damage??
Thanks in advance for your comment...:biggrin::biggrin::biggrin::biggrin:
xtremeleo
3,247
464
5,183
most importantly, do u alwiz change gear lembu-style? i think the synchros are out, anymore points u wanna tell? changing to a better gear oil does help, but up to a certain extend ler
drewn123
220
Ever changed ur gearoil?
When?
yeah, i did changed my gear oil.... I think almost 6mths liau. I wanna get some feedback, so i can fix it all in 1 shot instead change oil and the problem still persist..
Thanks
---------- Post added at 03:48 PM ---------- 6 hour anti-bump limit - Previous post was at 03:40 PM ----------
lembu style?? Sorry, i don't understand.. :biggrin:
Other point? Just that when I stopped at the R&R, when the car is idle. The gearbox is still heavy. i.e. shifting to 1,2,3,4 and 5 gear will be heavier than normal. But after resting awhile in the R&R, maybe around 15mins. Then the gearbox is normal again. But after i continue my journey for another 1-2hrs, the problem came again.... :confused:
Now, during normal city driving.. The problem of heavy shifting ain't there. As i said, this problem only occur when I'm using constant 5th gear for maybe around 1-2hrs on the highway. And as i went into R&R and downshifting, the gearbox are heavier than normal.
FYI, wat is synchros?? How much to fix the synchros if tat is the problem???
SataniC
Old Is Gold
1,885
81
5,148
Subang
rm500 a pop last time if i remember correctly...
1-2 = 500
2-3 = 500
3-4 = 500
4-5 = 500
i tot syncro koyak is when u get the crunching sound when changing gear? always koyak my 2-3 syncro during the good ol days...hmmm
Shoken7
193
satanic..where do you change your synchros?
how much is the labour?
drewn123
220
1-2 = 500
2-3 = 500
3-4 = 500
4-5 = 500
no... no crunching sound... Just very heavy to downshift from 5th to 4th cuz slowing down while entering Highway R&R.. Even when i stopped my car, shifting from N to any gear seem to be heavier than usual... However, after a few minutes cooling down the car. The gearbox seem fine...
As i said, only happen after cruising the highway on constant speed on 5th gear. So far haven't encounter this problem while city driving...:biggrin::biggrin::biggrin:
xtremeleo
3,247
464
5,183
lembu = kasar, harsh, etc. lol
so, did u?
---------- Post added at 08:43 AM ---------- 6 hour anti-bump limit - Previous post was at 08:41 AM ----------
ohh, i'd check the linkages first if i were u. lubricate them and see how it goes
xteiner
99
3,008
1-2 = 500
2-3 = 500
3-4 = 500
4-5 = 500
1-2
3-4
5-R
correction =D
Shoken7
193
anyone knows how much is a reasonable labor fee to take down the gearbox and replace a synchro ?
cat77
3,865
16
try leman puchong.......i heard his labour charge among the lowest......thanks
The Marketplace Top Posts
I just purchased a toyota matrix '04 XR. I would like to get a cool air intake and or a exaust system. I would like to know what to purchase and in what order should i purchase them and or any other car parts like pulleys and such. Where i should purchase it? Should i have someone else install it for me or should i do it myself? I'm new to all of this and would like to make the best of my car. Also, i just purchased a new car radio (Alpine) and had it installed... What do you recomend for a...
