EK 4 Door Rear Screen With Wiper
camshaft
411
10
i'm not using fake...ek4 got original rear wiper...the control switch is on the left stick...same place with the front wiper...u need the rear ek4 dashboard....or u need to modified and drill a hole on the rear dashboard...
cad843
403
12
3,018
Oita Ken
Bro, thx for the info. If not mistaken, rear dashboard can change the skin only rite? is it enuff if I just change the EK4 rear dashboard skin?
Can u shows some photos of ur dashboard? I only bought the rear windscreen and control switch ... without rear dashboard ....
camshaft
411
10
here u go...
the motor
the switch
the rear dash
cad843
403
12
3,018
Oita Ken
Thanks bro, I have bought all the necessary parts, already install except waiting for wiring and to be done by this week. Thanks for the photos ... easy for me to identified all the parts.
BTW ... did you install water spray for your rear screen? .. I notice the switch there gotta function and also 1 more additional wire beside for wiper function.
camshaft
411
10
hehe..cheers! mine ek4 ori...so it's already has water spray function on the top of the rear screen...but when it try to spray the water...it doesn't came out...mybe the tube stuck somewhere...so lazy to check it out...beside it's not so important...:biggrin:
cad843
403
12
3,018
Oita Ken
Bro, seems like ur wiper "batang" / blade or what ever its name a bit differ from mine. The one outside the rear screen from motor socket. Can I use ek9 or 2 door at 4 door? I suspected the one I bought already "rojak" by the seller.
Do you mine to snap a photo of ur wiper, the one outside the screen? Thx a lot. Cheers .....
camshaft
411
10
your's been rojak? i tot mine been rojak..even it's an ori ek4..i never seen any ek use the same wiper like mine....bout the ek9 wiper use on ek 4 door...i cant cnfirm that...but if your wiper is in good condition and functioning...why not just use it...
cad843
403
12
3,018
Oita Ken
Wiper bracket bend a bit laa ... seller said he dont have anymore bracket except that one. So he straighten back using hammer in front of me. Wiper works very well ... but look not so nice due to its shape a bit awkward. Urs using ek9 bracket arr? If can use try to look for it later ...
mrpilot
91
1,508
i'm digging n found this thread. also want to install my rear wiper screen. is it true that need to weld somewhere, for the motor? n where did u do the wiring. accessory shop can ah?
cad843
403
12
3,018
Oita Ken
Yup ... minor welding and drilling need to be done to install the motor. Im not very sure bout ur car ... but mine wiring and socket already there ... no need for me to lay new wire ... maybe u can check first.
Wiring connection done at 1 shop somewhere at Industrial area SS25 S.alam since its recommended by my friend and not very far fr my house.
For control switch installation ... u need to open the steering wheel. If ur car with Airbag ... better done by somebody familiar with Honda ... if not ur Airbag might not properly work or install back. Just my advise .... but its up to u lorr
Mine is w/o the water spray at rear windscreen ... its just wiper and windscreen heater. Good luck on ur installation
Hi some personal write up FAQ for Heat Shield and Grounding DIY.
DIY POD Heat Shield : http://www.savefile.com/files/5058854
DIY Grounding : http://www.savefile.com/files/8461724
...link is only valid for 14 day....
They were done on an S13 200SX but should apply well to any car.
hope its helpful!
