biz-da-tech
520
RM175??? are u sure or not... bridgestone potenza Re001?
195/50/15 already 250 to 270RM
and 55 cost Rm 3XX >.>
where u get got location got time i must go take bus to KL buy tire
Milo33
185
i reconfirm back next week i back my hometown bro...
if not mistaken is re001 la..:rolleyes:
alamdamai1
59
hi, i'm planning to undertake an adjustable cam pulley/gear mod very soon....but before that, need the help of Sifus here...
i've noticed the cam timing for our 4G15 is different between a Carbie and EFI models..append below is the spec sheet...
hence, can anyone confirm this and if so, would it be worthwhile to change my stock Carbie Cam to the EFI version for better engine efficiency as the exhaust valve timing for the EFI opens later compared to the Carbie model...
members advise is highly appreciated...many thanks... :help: :help: :help:
Milo33
185
bro,paiseh la..it's not bridgestone potenza re001...
it's yokohama tyres the thread almost similar..Lol:banghead:
sorry taiko..
ettm_14
605
81
bro,
your comparison also not ngam already, unless you are driving a twin cam 4g15 EFI, if not the image you appended is of no use...one is SOCH 12V and another DOCH 16V
if i am not mistaken both carbie and efi for SOCH has the same valve timing, hence it is not feasible for the change,this is for 4g15P engines
just get yourself a street cams would do, coupled with adjustable cam pulley
correct me if i am wrong,..
cheers
alamdamai1
59
bro,
cheers
haiya Sifu ettm_14, thank you very much for pointing out on my error...yealah, i didn't notice the quoted spec's is for an EFI DOCH engine...really appreciate your invaluable advice here..:adore::adore::adore:
klywh1
39
1,508
Hi guys, I'm using 4g13 now and i was wondering whether i could stroke it up to 1.5litre by fitting in 4g15 head. Possible?
Sifu Guan. Drex,
I think hildagarde wanna to tell that possible to fit in piston 1.5 into 4G13 block(by rebore the 4g13 block) which is possible & discussed very detail in previous tread :biggrin:
Hildagarde
I am refer to hildagarde if u choose to proceed stage rebore 4g13 block to fit in 1.5 piston than better do PnP head, adj cam ger, PZ cam,engine balancing together saving for the workmanship :wavey: Now I seldom get online due to my job very busy in penang try to read all the previous tread u will get the info u wanna esp input by all the sifuuuuuu in ZTH happy modding. Price u can refer to sifu Guan & drex since they handled my stocknia project previously :nurse: if u wanna do a 4g13 rebuilt with performance parts including 1.5 piston, PZ cam & blarrrrrrrrrrrrrr
drexchan
2,908
100
Bukit Jalil
drexchan.fotopic.net
Sifu Guan. Drex,
71mm to 75.5mm? That's 4.5mm bigger, 2.25mm on each side. How thick is the cylinder liner?
afosz
12
Selangor
Hey guys, I'm new here driving Wira 1.5 AT.
My TB got a bit of a problem right now. My mechanic said that it got problem with sensor or what and now it is like useless. He mod it so that the car still can be drive but not sure how long it will last.
So the current condition is, during idle, if a/c off, the timing will go up and down, a bit jerking and exhaust sounded like poof poof. If a/c on, no problem. This is how my mechanic mod it.
tigger5251
240
27
Good Luck!
FVel
716
242
Sounds like a car Chow Sing Chi will drive. A/c 'on', no problem. A/c 'off', "poof! poof!"
hehe Sorry....I just found you post funny
afosz
12
Selangor
u are telling us how your car behave... not how your mechanic mod your car...
Yes I know. He said my tb got problem already, something to do with the sensor or what I'm not sure. Usually he would suggest to change, but since it is costly, he mod a bit, add motor or what I'm not sure so that it is usable for temporarily. In the mean time, I'll save money so later can afford to change tb. The condition after he mod is that I need to switch on a/c so that it feels ok. If off a/c and idle, the car will be jerking like a lot.
Sorry, automotive noob here and trying to learn more. :D
Erk, the "poof! poof!" sound is from exhaust, like coughing. Explaining here sounds funny though.
anybody can recommen me in kajang area or cheras area got any workshop "pandai"modify turbo chargr engine?my car is kancil L5 wan change turbo so any sifu can recommen me?
