How to know Rx8
InitialD
1,299
93
According to Bermaz, the new facelifted RX-8 has its reliability improved as well as more compatible with local weather) than the recons (even compared with post-2006 auto models). Is this true??
Might be true... as the earlier batch of the RX-8 have a known issue with the electric power steering which will judder violently when starting the car from cold. It cost around RM5000 to replace it.
On a side note, did you know that the RX-8 was featured in this book in MPH Bookstore called 501 Must-Drive Cars?
benyeap
244
2
Just found an 03 rx-8 auto unreg at 125k, guys is it a good buy? really eager to get one before cny
rodcyprian
143
17
hey hey ... is RWD car easy lost control .. .. ? ? ? ?
RWD is more fun to drive~ If you can control it well:driver:
I got a friend bought a 4speed auto one not up to a year & sold it coz he said not enough power bro~ now he use 350z and said thumb up:vroam::vroam::vroam:
learning86
247
3,018
any1 know friend/dealer ...help me easy done the downpayment hhuhuh.. ..
benyeap
244
2
Just saw the 2003 Rx-8 unit the other day but it was booked. The engine was left running by the dealer there, maybe for warming up purpose? I can feel it is sort of vibrating above normal. Is this okay?
rodcyprian
143
17
new car, vibration? shouldn't be like that, it's abnormal for a quit new car!
Lennon
1,050
2
Yes, becos there are only 2 mountings supporting the engine n gearbox........ Unlike other cars which have 4 mountings.... Morever the car has been manufactured since 2003......
effie
319
9
3,018
Shah Alam
www.rx8clubmalaysia.com
Main cause of engine mounting failure in the Rx8 is the rubber hardening (due to the high heat nature of the Rotary engine), which results in the mountings leaking fluid due to cracks in the rubber seals.
The Marketplace Top Posts
hi big big sifu,
which wire i should tap from distributor to RPM meter??
as i found, distributor got 2 wire come out which is BLUE and whiteblack,
so which wire i should tap from for RPM meter to run??
because tap wrongly will void the warranty of the RPM meter!!
thanks alot for the help!!!
