Difficulty achieving top speed
Shinjite
864
120
Klang
From 4000 onwards you are running too rich
Try to get nearest to 13:1 if possible, you need a piggyback already :D
meltan7
619
32
Kelana Jaya
well, i let the tuner at under5 do all the work. it seems that this is the most efficient setup.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
i let you guys be the judge of it.
here's my dyno chart.
u what engine liao ah??... why ur AFR drop so drastically??.... power no increase drastically also... after 4k rpm AFR consider rich for NA engine... if get about 13 u can have more power gain...
Shinjite
864
120
Klang
His is a 4G15, his low end also a bit too lean but still okay
4000 rpm onwards rich all the way till high end. His power delivery is linear so its okay
With ECU mods, expect close to 90WHP ;)
meltan7
619
32
Kelana Jaya
4G15 bro. i suspect my GB is dying.
blind_lan
33
my advice..
better go back to powerzone..
seems many thing u had done there..
"ade jugak yg bikin dgn powerzone tak menjadi.."
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
jombiee
950
13
3,018
Ghombau
just throwing you out something to consider.
how about doing some compression test first, its easy. lost compression might be the culprit.
since u have upgrade cam & header etc, you have dyno for AFR right, where is your piggyback ?
sometimes worn out main & con rod bearing & others rotating part will makes your engines heavy & could not go further.
Do you really needs adjustable fuel regulator for your setup ? I dont think so. Why not remove it & tell me if you gain significant results by using fuel AFR.
cheers
meltan7
619
32
Kelana Jaya
Is your GB slipping?
the gear changes are not smooth. slight jerk whenever it changes.
saya tau siapa... haha... :rofl::rofl:
---------- Post added at 06:03 PM ---------- Previous post was at 06:03 PM ----------
gearbox can slip??... or u mean clutch??...
---------- Post added at 06:04 PM ---------- Previous post was at 06:03 PM ----------
4g15 svdo??..
MMC bro.
cheers
haven't got a EMS yet. probably later on. what's the diff between AFR and fuel AFR?
WhiteLighter82
30
Me 4G91(manual) also having problems achieving top speed......suppose to be able to hit 180km/h.
But current top speed is only 150km/h - 160km/h........
I wonder if the TPS setting has anything to do with it...........
blind_lan
33
gi jer kt Pzone tuh..
say to him...
"bang ape nih bang,..? ckp bleh bg power..160 pn tak sampai..tak kan nak suruh sy sumbat supercharger pulak..??"
"rugila camni.."
hehe... no heart feeling yeh..gurau2
Anyone tried this? It is an immobilizer that is built on existing security system (so 2 security system in 1 car as opposed to taking existing system and switching with another). What it does is that it will immobilize ur car after 40secs since pressing brakes if correct code is not input to a console. Costs RM1,100 to install. Opinions?
http://www.junik.lv/~meg/BlackJax_4.htm
