4G15 bro. i suspect my GB is dying.u what engine liao ah??... why ur AFR drop so drastically??.... power no increase drastically also... after 4k rpm AFR consider rich for NA engine... if get about 13 u can have more power gain...
saya tau siapa... haha..."ade jugak yg bikin dgn powerzone tak menjadi.."
gearbox can slip??... or u mean clutch??...Is your GB slipping?
4g15 svdo??..4G15 bro. i suspect my GB is dying.
the gear changes are not smooth. slight jerk whenever it changes.Is your GB slipping?
MMC bro.saya tau siapa... haha...
---------- Post added at 06:03 PM ---------- Previous post was at 06:03 PM ----------
---------- Post added at 06:04 PM ---------- Previous post was at 06:03 PM ----------
4g15 svdo??..
haven't got a EMS yet. probably later on. what's the diff between AFR and fuel AFR?just throwing you out something to consider.
how about doing some compression test first, its easy. lost compression might be the culprit.
since u have upgrade cam & header etc, you have dyno for AFR right, where is your piggyback ?
sometimes worn out main & con rod bearing & others rotating part will makes your engines heavy & could not go further.
Do you really needs adjustable fuel regulator for your setup ? I dont think so. Why not remove it & tell me if you gain significant results by using fuel AFR.
cheers
argh...sorry, its the same, just remove the afr & test, by using & not using Adjustable Fuel Regulator.the gear changes are not smooth. slight jerk whenever it changes.
MMC bro.
hahaha.. good point bro!gi jer kt Pzone tuh..
say to him...
"bang ape nih bang,..? ckp bleh bg power..160 pn tak sampai..tak kan nak suruh sy sumbat supercharger pulak..??"
"rugila camni.."
hehe... no heart feeling yeh..gurau2
say to him...
"rugila camni.."
won't the fueling be inaccurate without the AFR?Do compression test needs money and not cheap too
So taking out the AFR and test again is the better alternative :)
Mel, time for a manual GB ;)
