Sonic Thunder
333
guys,can i fit a mivec 1.6 head on my 4G15 block?
is it possible?
any xtra mods to the e.c.u and etc?
thanx!
---------- Post added at 03:57 AM ---------- Previous post was at 03:57 AM ----------
is it possible?
thanx!
aLoM
28
1,503
Anyone mau tolak front brake upgrades for iswara? Looking for IMP formula rotors. any feedback on this? after upgrading the front them might wanna change the rear to disc. Any comment?
aLoM
28
1,503
The thing is, VR4 brake system are not easy to get here in Sarawak. Even most of the after market parts i got it on9. So if u guys got anything to tolak, just pm me. If im not mistaken there are a few gen of this vr4. 6,7,8th gen. which one is the most suitable. Enlighten me mr Skywalker. Big fan of ur blog here. :)
Sonic Thunder
333
sifoos...need ur opinions before i proceed to install da mods i hv in mind...
im drivin a wira wit 4G15 injection auto trans...
plannin to put a open pod wit heatshield...(doesnt cme wit air flow sensor)
cold air intake...aftermarket plug cable...denso iridium..full piping...
need advice on piping set up..and my choice of filter...
thanks alot!
cheers!
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
should be the 6th gen vr4... there are single pot and twinpot to choose from... single pot ones should be sufficient unless ur car producing big power exceeding 150whp...
what car u driving??... if wira, i recommend u to get mivec brake set... single pot also... if saga iswara, plug and play ones only mirage turbo and rvr brake set... for saga iswara, make sure ur tie rod is fixed from the top into ur knuckle... if fitted from the bottom like wira, u'll have weird steering feedback....
thanks alot!
cheers!
try get drop in air filter such as k&n... remember to do cold air intake as well because wira oem cai snorkle is restrictive...
dont need aftermarket plug cables... ur oem plug cables are good enough... tested by many of us already... yes, use better sparkplugs do help... if u have money can go for iridium, although IMO its a waste of money for stock standard engine... platinum ones should be sufficient...
as for exhaust piping... get 4-2-1 extractor... 1.7" piping... decat replace with straight bullet... use s-flow muffler with inlet no bigger den 2"...
aLoM
28
1,503
Driving iswara bro. Can you define wierd steering feedback?usually how much does the brake set cost?i just got my steel braided hose delivered recently. yet be be installed.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
cannot define it myself as i've never experienced it before... but almost all who upgraded to vr4 brake set with tie rod fitted from the bottom does complain about weird steering feedback, especially when suspension travels up and down (go over uneven roads).... so i guess there are serious alteration on toe and camber when the suspension travels up and down...
AD_EG
6,328
231
Ipoh
thanks alot!
cheers!
if you driving auto better not put open pod .... you need low to midrange power cause you are driving auto....you should use drop in air filter....
use 4-2-1 extractor + 1.7" or 1.8" piping + S-flow muffler
drexchan
2,908
100
Bukit Jalil
drexchan.fotopic.net
cannot define it myself as i've never experienced it before... But almost all who upgraded to vr4 brake set with tie rod fitted from the bottom does complain about weird steering feedback, especially when suspension travels up and down (go over uneven roads).... So i guess there are serious alteration on toe and camber when the suspension travels up and down...
bump steer.
Sonic Thunder
333
bro Skywalker and AD EG,
da piping set up dat u r suggesting wouldn't be too loud right?
ive already took owt my OEM CAI...now running on aftermarket CAI...
thanks 4 da info bout k&n drop in...will do it very soon...
im abit worried of da loudness if i replace da cat wit a str8 bullet...
dats all...
thanks 4 ur time sifoos!
mat_mr90
33
Hi .... sorry "tumpang this tread".. i just bougth 2nd hand wira aeroback and plan to put evo3 seat complete set. Can that seat nicely fit to my car. I just worried the rear seat.. any one can give the opinion or already have the experience
thanks
would like to ask is it practical to convert a subaru sti version8 into a rear wheel drive?....n is there any carbon kevlar hood n boot available around...like wat brand n stuff...tanx guys..help kindly appreciated
