GSR / Evo final drive
spuzzle
741
9
Kuantan / Perth
Hi all,
I am currently using evo2 gearbox with 3.909 final drive. First and second gear is too short for me to launch the car.
1. Does a GSR 3.545 final drive bettter if I change it with my current 3.909?
2. Can it fits in my evo2 gears?
3. Or it is better if I change to evo3 gearbox + 3.545 final drive?
Thanks in advance for all sifu's help.
jinkl
4,624
376
3,183
Hi all,
someone gave u misinformation
final drive gsr is 58/15
final drive gsr rs is 61/18
evo1 is 64/15
evo 2,3 is 63/15
errr none of it is 3.545 and 3.909
3.545 and 3.909 is only if u r using 4wd and the ratio is for rear diff ratio
wht do u mean better, ahak thts very important
some ppl like short girls
some ppl like girls with big breast
some ppl like girls with small breast
some ppl like girls with long leg
so if i come n tell you , i want a better girl , err do u know my taste ? hehehe
thts the quesiton, diffrent purpose has diffrent gear ratio and diffrent power range and rev range will have diffrent ratios also
a drag ratio
a 1000hp 400m ratio
a sepang track ratio
a shanghai track ratio
a gymkhana ratio
a wangan/highway ratio for a 10hp car :P
:D , so u must let us know ur car power , ur purpose of it
u put a very very long ratio on a underpowered car
the car will suffer , if u do ur ratio for 300kmh but the car has only
200hp , its not suitable at all rite ? , u put a very very short ratio until 160kmh on a 1000hp car for drag race errr suitale or not ? shanghai track maybe longer than sepang track in the straight line , so shaghai track will have a longer gear at the last gear , so jst like tht, just saying
thank you , hehehe
spuzzle
741
9
Kuantan / Perth
evo1 is 64/15
evo 2,3 is 63/15
a drag ratio
a 1000hp 400m ratio
a gymkhana ratio
thank you , hehehe
insufficient info = kena shoot again......hahahaha......newbie here la bro
i like big breast and long legs, where to find? anyone can supply? hehehehe
back to topic.....my car is satria with vr4 engine running 370whp / 42kg-m torque.....before this i use mirage 2wd gearbox which the ratio not match causing lag when engage 3rd gear.....then i change to evo2 gearbox and now the ratio is close.....but now the first and second gear too short for me to launch the car......car use for 300m drag.....how to solve the problem......plan to change the final drive or any better suggestion?
jinkl
4,624
376
3,183
back to topic.....my car is satria with vr4 engine running 370whp / 42kg-m torque.....before this i use mirage 2wd gearbox which the ratio not match causing lag when engage 3rd gear.....then i change to evo2 gearbox and now the ratio is close.....but now the first and second gear too short for me to launch the car......car use for 300m drag.....houtw to solve the problem......plan to change the final drive or any better suggestion?
hehehhe wht i noticed with personal experience with tht hp n torque
if u use evo gb , and gsr final drive , the first and 2nd are long enuff , nice
but the 3-4 is superlong hehehe , 4th gear u will achieving 190kmh
if tht is wht u want, then go for it , fifth gear becomes one lembap shit
a fren of mine did the same , evo gb + final gsr + gear 5 gsr , the gear 5 seems more
suitable for tht hp range , with 370hp i doubt u will reach 300m with 4th gear 190kmh , wht is ur current speed on the 300m line , one more thing
if u play highway too , if someone comes and cucuk ur backside when u r driving 110kmh , the gear to drop last time was 4th gear rite, now u have to drop to 3rd if not he is gonna still be cucuking ur backside
another common formula i see is
gsr gb , 1st,2nd gear from evo
very nice gearbox also
slivero
576
gsr with 270whp.....now using gsr gbox with vr4 fd 64/15...
1,2nd short...3,4th long.....or is it better use evo gb , and gsr final drive to make
it 1,2nd long gear??
Bump: gsr with 270whp.....now using gsr gbox with vr4 fd 64/15...
jinkl
4,624
376
3,183
if u want longer 1st and 2nd, take the evo 1,2 gear n put into ur gsr gearbox
errr just asking, y did u shorten ur gearbox by putting bigger final drive
for me gsr standard gearbox is really nice for 270whp car
goo_61t
660
12
hurmm i think i know this "GUY" lalalalllalalalalalala
spuzzle
741
9
Kuantan / Perth
jin, 300m range i can reach around 200kmh if i not mistaken....with this evo gb, fourth gear i tested to the max at 220kmh follow by fifth gear at 260kmh.....i think this gearbox is good enuf since the ratio all is close and no lag from 1st-5th gear....maybe my expectation is too high, hehehehehe......ur word "cucuking" makes me laughing whole night:biggrin:
spuzzle
741
9
Kuantan / Perth
jin, is it 64 the final drive ( big gear ) and 15 the shaft gear?
means bigger final drive 64 can drive those 1st-5th gear longer,
and smaller shaft gear 15 gives lighter response?
just what i imagine, hehehehe
goo_61t
660
12
imagine like motorbike sprocket... put smaller front(input shaft) and bigger(final drive) rear then u get pickup like hell,put bigger front,smaller rear pickup suffer,top end walauwweeee...,but remember to pair ur final drive together with with the small shaft,they comes together or u end up grinding ur final drive
jinkl
4,624
376
3,183
spuzzle u can contact goo_61t , he is a gearbox expert like shepherd :P
he been doing mix n match gearbox from early age of 17
currently he is working for Tata- India , to make a ratio for trucks and scooter
goo , how is ur shop in kepong , kekekekke
selamat pagi :P
goo_61t
660
12
selamat pagi :P
meaaassiiiihhhhhhhhhhhhhhhh :p
yopo
274
25
selamat pagi :P
FUYOOOO.....!!!!!!!
goo_ is gbox expert now..kekekeke:listen:
Trinityblood
3,371
21
come on la goo...share some info...spuzle is monster in da making he need the g.box info...:rofl:
goo_61t
660
12
come on la goo...share spm info...spuzle is monster in da making he need the g.box info...:rofl:
aiyaa me chicken only maa..jinkl,yopo,3rdgear dogbox sifu some more, plus i took SPM long time ago laa bro wakakakakaka
spuzzle
741
9
Kuantan / Perth
we want to know chicken chicken stuff....dogbox cant afford yet:banghead:
trinity, how is last night game....whats the result?
yopo
274
25
but to tell you the truth..the gbox recipe is a very sensitive matter to many workshops
many claim as their 'secret recipe' maa...some do it that way..some do it this way
depends on the need and apllication..huhu:rolleyes:
Trinityblood
3,371
21
aiyah...eror oni ma...huhuhu..jinkl edi give some..so mind share some to us.:adore:
Trinityblood
3,371
21
cancel bro...they go to pekan but we dint since i noe the opponent(kaki ken**ng) there
they call ap*s...haha i thing yopo familiar wif him...
since u edi at aussie go survey the ppg dogbox bro..muhahahaha:listen:
spuzzle
741
9
Kuantan / Perth
thats true yopo.....'secret recipe'.....weapon for 'cari makan'
need to pay franchise fee to get the recipe.....hahahaha
goo_61t
660
12
goo , faster bring out ur mirage recipe, dont laa secret :P
50gm of butter
2 table spoon of sugar
a sprinkle of salt
2 ltr of water
put in oven for 35 minutes,and u get urself a long ratio gearbox wakakakakakakakakaka
Hi,
I'm looking to change my Nissan Sentra's brake pads. Seems to have worn down de.
Can you all advise what kind of brakes to look for when I ask the auto parts shop for brakes?
I dunno the brands/types available out there.
Do advise.
Nissan Sentra 97 B14, 1.6 Manual, no ABS.
