On Wheel Dyno
JackWaiKit
262
5
www.friendster.com
Hello everybody!!!:proud:
Good day to you!
Any idea with the on wheel dyno no matter on VTEC, MIVEC, 4A series,GSR, EVO & Vios, City....
Pls share your experience on this!!!:biggrin:
DaDoctor
422
2
It depends on what is ur management system...
if piggyback like e-manage is around rm300-rm500
If standalone would be more expensive....:banghead:
JackWaiKit
262
5
www.friendster.com
I asked Northen garage at Penang,
It cost bout RM200++ include setting for VAFC & adj cam pulley!
Pls share ur hp afer dyno pls!
UDT-SB
28
1,503
i got mine 1.8mivec. juz mivec silvertop, 4-1 header, cap ayam exhaust, 1.8 piston, safc blue screen n rspec to activate mivec....ecu use back 1.8(0405)...on wheel is 153whp.
catan
173
3,018
Png
I tuned Emanage only cost Rm3XX at Northen garage... 189BHP...
ehdrian
I Don't Care!
3,310
280
1,683
oh wat car u drive, catan?
JackWaiKit
262
5
www.friendster.com
wow...153whp!!!
Impressive!!!
I'm planninf to dyno my mivec too!!!
But stilll considering it whenever changed extrator or piston on Jun cam!!!
But no $$$ so far!!!
Well nice to meet u!!!
Don't smoke me when u see me in north area ya!!! ;)
zac
1,347
231
Johor Bahru
wow...153whp!!!
Impressive!!!
Can change mivec piston first ah... cheap and significant improvement!! what kind of extractor you plan to use?? i am using hotbits 4-2-1... Jun high cam? really? very very expensive oh... and low end torque not so ok right?
mivec RS
49
hai friends,
mine dyno and setting afc neo $180 , dyno shop at kuantan . mivec 1.8 with flat piston got 148whp . rev cut only 7.5k . need more money to squeez more juice .hehe:driver:
JackWaiKit
262
5
www.friendster.com
I didn't paln anything yet...coz eco crisis!!!haha:biggrin:
But hi cam is not really fit for street use...just lucky i just install adj cam gear 1 yr ++...so that still can catch back timing in future geh...but so far no diff lah after install adj cam gear....!!!!
Just a same question in forum : mivec 1.8
ur foreman said mivec psiton need 0.8mm gasket
buy u r using 0.4mm....then egine overheat rig?
So what if v jus combine 4G92 piston wih 0.4mm....
My foreman don' recomend me o wase $$...
he said no really significant unless i oversize piston then also change to mivec togther!!!
And just improve high end torque....
But putra stock eng block, clucth & gearbox can't tahan(longer last)!!!
Any comment?
mivec RS
49
hai friends ,
what i know from my friends if u are using high comp piston u need to calculate the comp ratio . if to high u need to run the engine with high ron fuel . correct me if im wrong .still in learning stage :biggrin:
hafiz4g91
30
1,508
is anybody knows dyno place in jb excluding viswork. last time i go to viswork sooo expensive la. need to know for my next mod......
Hi guys, yesterday went to Links for the carbon fiber air intake, but unfortunenately my car cant fit well, need some modification... :(
1 of the way is need to change the car battery to a smaller size, and i currently driving a 2.0AT car that using NS70 battery, so can i change to NS60?
They also recommend me change the battery to a smaller size for more easy to mount that filter. They said the if i change to a smaller size of battery, it wont effect anything..
is it true ka...
