Toyota 2E/3E-FTE & 4E-FTE Pistons
wira_tak_laju
4,184
2
Toyota 2E/3E & 4E-FTE & Daihatsu K3-VET Pistons
These all are genuine original Toyota and Daihatsu Turbo pistons
Toyota Starlet 2E-FTE/3T-TE EP71 Turbo Pistons 1986-1991
NEW in original packaging and 100% Japan Made
-Fits all 73mm bore: 2Exxx, 3Exxx, only standard size avail
-8.0.1 comp
-package includes 4 pistons,pins and and high quality RIK/NPR Japan rings
UPDATE 25/04/2010.ALL SOLD OUT
Anybody wanting to pre-order,have to wait 21 working days and 50% deposit required.price rm650 with rings
Toyota Starlet 4e-FTE Pistons 74mm
-Fits all 74mm bore: 2e,3e,4e and 5e
- only standard size avail
-8.0.1 comp
-price RM630 with piston rings
-stock available
PLEASE CALL 016-2458121 OR 012-2457049
stock 4E-FTE side by side with forged ross pistons 4e-fte..Note : same compression
jhoonaun
170
is this new item ? i mean brand new item ?
and i have one more doubts. just by changing a pistons will lower the compression rate already ? even thou running on NA engines.
wira_tak_laju
4,184
2
its brand new bro..u masuk this pistons difinetly reduce ur engine comp ratio altough on NA engine.the difference on NA or turbochrged engine lies on pistons compression ration and head gasket thickness
jhoonaun
170
ok.. does this fit myvi ?
i know myvi is 72 mm..
but wat does bore means ? isit the hole for pistons to move in and out ?
and the handle for the pistons like that 2 item comparing picture.
" stock 4E-FTE side by side with forged ross pistons 4e-fte "
that thing on top of the piston.. will it be able to suit on to this item ?
sorry i ask many questions but i just want to be clear of everything.. and i did ask u regarding ur other piston's thread also.
wira_tak_laju
4,184
2
bore is cylinder size..ur standad bore size 72mm.so need to re-bore to bigger size 73mm..both 4e-fte and 2e pistons ngam with ur engine..but i recommend 2e one as its compression is more lower to support high boost
Just wanna share my lazy DIY project a last month. Yeah, last month. LOL.
So, I found these cheap ass NOS taiwan Enkei replicas on mudah. I like the design but I don't like the color. Lime green is a No, No. So, time for some DIT session. I use cheap ol Anchor rattle can in Flat Black color coz it's easy to apply and I'm lazy. All the painting was done before noon around 1030am-11am.
The rims are not that light but at least it's lighter than my old rims...
