another disc brake question...
heir_rule
142
Is there no risk if we modified the bracket bro?
bcoz thinking of fitting 4pot FTO at my wira but then heard if braking "tercabut" la.haha.
got scared automatically fitted 2 pot Evo.hehe.
jaydee
334
Subang Jaya
Bro FTO is only twin pot, like Evo....
GTO is 4 pot... :biggrin:
hi to all zth members out thr...i wanna ask sum few q here...
curently i'm driving a satria 1.5...n i using 17' work emotion cr kai..i think offset is 40...
i wanna change to nissan RB20 4 pot caliper n 280mm rotor...izzit any prob to fit into my car..??
n any better place in KL to mod the caliper n rotor??the price ruffly how much??
thx in advance...
Basically the Nissan 4 pots are even cheaper than Evo Twin Pots the last I heard
(I'm assuming you're talking about the R32 GTS 4 pot version.)
The most expensive part is the bracket you need to make to fit the Nissan braking system...
You can also get the GTO 4 Pot with bracket also - as there are ppl actually custom making to fit Wira/ Satria/ Putras... go search... abit more expensive then the above, altogether I think RM1200 + - but it looks much better and bigger.....to me at least..... (The calipurs with the Mitsu sign)... its all up to you.... :biggrin:
ganfh
462
Bro, why not you try twin pot 1st? Match with good pads sure sedap!
But if u want 4 pot just upgrade ur servo to bigger ones as well otherwise.......
Sifus, if we use 4pots front but back stil using single pot will it make the braking be kinda off balance? Thx:driver:
jaydee
334
Subang Jaya
Well... Many ppl don't really care if its not balance.... unless you're a pro driver, racing in tracks etc.. lol.. then you must know exactly what you want ler...
But I heard from somewhere the best would be like 60% front - 40% back, thats If you wanna calculate exactly ler..... :biggrin:
Twin pots with good pads is good enough... (There is another post on brakes I replied the other day... :biggrin:)
Unless you want 4 pots for shows, no problem... up to individual....
Just don't put the 'Brembo calipur cover' :banghead:... my 2 cents :biggrin:
heir_rule
142
actually bros what is the method they use to custom made the bracket?
is it CNC machining? if its true no wonder the price is high.
hi there
i need some advice on camshaft and abjustable campulley
izzit high performance cam shaft can increase power and fuel economy??
and how about abjustable cam pulley
and wat is automatic cooler?? does it exists??
any sugestion on modification to inrease power of proton gen2 auto??
