my 96' Satria is a UK Spec Satria. The difference are:
1) Dual reading speedo meter. MPH is on top and more visible than KMH which is only small under the MPH numberings.
2) Also, not only the speedo meter is in MPH, the counter is also in Miles.
3) Aircond panel is different. It have "winter" button. When it turns to blue color, means you have cold air coming out and when it orange, it blows hot air.
4) Proton also installed an ABS-like brake assistant at the brake pump. But rosak already and i have removed it when i installed a new brake pump last time.
5) The dashboard panel is attached with carbon fiber like panel. Others 96' Satria is only fitted with normal black dashboard panel.
Thats only the differences. Owh yea, it comes with SRS airbag steering (4 spoke).
Hope that helps.
