Need some opinions - TEIN/TANABE?
G221
Over 10,000 RPM!
13,344
61
Guys,
need some opinions...which one is better in terms of handling, comfort, etc?
Tein S-tech or Tanabe GF210? both are suitable with stock absorbers. price wise...almost the same...any other suggestions?:burnout:
Greytezza
1,130
68
1,648
Truly Asia
Bro..what size is yr wheels and do you normally drive around with 4-5 ppl in the car?
Reason I ask is when u lower yr altezza, scratching of your car bottom will be a headache especially over our infamous Malaysian road humps with unstandardised height and width...:mad:
syahrul37
42
12
3,008
Tanabe is more comfortable and good handling...Tein is harder...Base on my experience...
G221
Over 10,000 RPM!
13,344
61
Bro Greytezza, 17"...Normally with 3-4 ppl...yes I understand the problems when lowering the car, but I think the stock springs are a bit soft. Or do u suggest to maintain the stock springs and go with aftermarket absorbers?
Greytezza
1,130
68
1,648
Truly Asia
G221..For a 17" wheel, I suggest just changing the shocks and maintain the ori springs..a harder setting shocks with the ori springs will work for daily driving.
But end of the day, it is still yr decision...:biggrin:
G221
Over 10,000 RPM!
13,344
61
alright..thanks guys!!!...will think about it.:burnout:
ryonan
246
normally people change springs. i think very rare people change absorber without the springs..
springs adjust height only...supports the chassis. actual "suspension" work is done by the absorber.
altezza is soft mostly due to the absorber. so if u want firmer ride but do not want to spend too much, i recommend to change the springs...but not the other way round. even better is to change both so that they are compatible with each other..
Recently my power steering hose was leaking...
My mechanic dismantle the hose and sent for re-machining a new hose...
Thought my problem was over... but unfortunately not yet...
Another section of the hose leak again, there was a long part, and and a shorter part of the hose.
In between the sections there was I think a pressure valve...
After re-machining the shorter hose, then I thought my problem is solved, but again no!
This time, when the power steering fliud is being...
