Guys...I am selling coil spring buffer(damper) for various car models..
Benefits of using coil spring buffer:-
Helps restore spring tension
Provides life to sagging coil spring
Reduces noise and vibration from suspension component
Improve stopping capability
Fast installation and obvious result
Suitable for all types of vehicles
Selling Price:RM60 per box(1 pair) or RM110 for 2 boxes(2 pairs)
NOW RM130 WITH INSTALLATION
Contact No: 012 565 8656
For installation service:
PIT STOP SERVICE CENTER
ENTRANCE C, LEVEL B1,
SUNWAY PYRAMID, SELANGOR.
Call me for more details
Buffer Sizez for Various Car Models
For those car models, that are not listed above, kindly arrange with your mechanic to measure the spring in order to get the suitable buffer sizes.
Refer below on how to measure:-
Installation guide:
1. Jack up your car. For safety, make sure it's stable enough.
2. Prepare solution by mixing dish washer detergent + water in a small bucket.
3. Deep the buffer into the solution and install them as the photo (slot coil into the bottom part of the buffer first)
4. Release the jack slowly and make sure all the coil spring fall into the buffer nicely.
5. Drive and go over few bumps or try to take some cornering to let the spring compressed into the buffer nicely
Sizes
1. Model A: Spring Clearance (47mm)/ Spring Thickness (13mm)/
Spring diameter (173mm)
2. Model B: Spring Clearance (35mm)/ Spring Thickness (13mm)/
Spring diameter (160mm)
3. Model C: Spring Clearance (27mm)/ Spring Thickness (10mm)/
Spring diameter (131mm)
4. Model D: Spring Clearance (23mm)/ Spring Thickness (10mm)/
Spring diameter (113mm)
5. Model E: Spring Clearance (15mm)/ Spring Thickness (9mm)/ Spring
diameter (112mm)
6. Model F: Spring Clearance (12mm)/ Spring Thickness (15mm)/
Spring diameter (120mm)
CLICK HERE FOR MY OTHER PRODUCTS
Installation guide:
Sizes
diameter (112mm)
