MR2\MRS Stuff to exchange\sale
max3821
137
all sifus,i m looking for mr2 sw20 power steering pump,i think so hard to find new 1,so who got stock? USED 1,urgent arrrr:adore:
iexit
1,874
59
1,648
Selangor
iexit.multiply.com
max, sometimes its just the relay which is spoil. Ask your mech. to test it first. If the relay is spoil then you can run a wire to by pass it and solve your problem. But you lose the speed sensitive steering.
------- STUFF FOR SALE ------
Price Reduced! Trade with other items i want also can :-D
HKS Intercooler (+HKS ori piping +HKS silicone) - RM750
Carbon Fiber Wing Add On (rare from Japan) - RM400
Poli-bush Gen2> for Caster - RM150
ETC Parts
RM100
RM50
RM100
RM50
Call 019 3840919
soff
457
13
HKS intercooler good buy, adds power...I know as I am using one. Ori HKS piping and hoses itself costs a bomb but even then a very rare find
tom's
2,865
76
subang
www.zerotohundred.com
err alvin,da blitz turbo dun sell arr..i want..da 245 engine kosong can less da price ar?
the eng kosong i might have potential buyer buying the whole halfcut.......when u want to take the turbo kit.....can't hold so long for you
5115
Nobody
5,952
2,254
fyi,sticked this thread for easy reference.
kazamai
80
next week,confirm..i cll u asap when my cek is clear..after raya poket koyak ma...heheheh..
MRMIC2
1,395
15
Item 1 & 2 - The PP & Bomex engine covers will prevent rain from wetting your engine bay (unless the rain falls 90 horizontally), looks cool, will help to expel more engine heat due to aerodynamics, lighten the engine cover
For Bomex the center bulge is higher and obstructs the rear view.
Anyway it is not a good idea to get moisture near the ignition system, electrical wirings and the fuse boxes.
Also note that the original engine cover was designed for intake rather than expelling gasses (vents are forward facing??)
Easy to install - Just rivet or screw onto existing cover.
It is advisable to remove the original engine cover vent areas for better cooling and weight reduction.
MRMIC2
1,395
15
5) Border FRP type Side Intake Scoops
Works on both original side vents and bomex style vents.
-will force more air into the engine bay thru side intakes. Does not waste air that passes by the vents.
Comes painted grey. Will be able to spray to body color.
if any one knows who can help me to install this to my fiat multipla car. iit cosist of attaching an actuator to the master clutch pump and hooking-up the auto-clutch computer to rpm sensor,clutch sensor,brake sensor.
while i belive any foreman can attached the actuator to the master clutch pump, i just a bit worried the eletronic part as it ma screw-up my car ecu.
anyone knows how have the experience installing this?
it suppose to make my car transmission like selespeed. make my life...
