REV Performance Garage Sales !!
andysky5
33,386
55
1,648
- All Parts are New and Genuine, unless stated otherwise.
- We provide Warranty for our Products...so you have no worries if anything goes wrong !!
:biggrin:
Engine Performance parts :
BPi Velocity Stack USA - HOT!!
WORKS Enginnering Products
Fuel Bank Evo II - HOT !!
NGK Iridium IX Spark Plug
Denso Iridium Power Spark Plug
NRG Racing Meters
EPS Power Charger
Sard Fuel Regulator - Original
Adjustable Fuel Regulator (Sard type) - Hot
Works Engineering Ball Bearing Air Charger
Super Ignite RSD
Surpass 9.8mm Performance Plug Cable
Original Tial Wastegate 38/44mm
Tial style Wastegate
Tial MVS Wastegate - Replica
Turbosmart Wastegates
Manual Boost Controller - Various Type
HKS SSQV replica Bov
Greddy Type-RS Blow Off Valve - New
Adjustable Fuel Regulator (OEM type)
Skunk2 Racing Intake Manifold
Throttle Body 65/70/80mm
Super90 Billet Throttle Body - HOT !!
Works Adjustable Cam Pulley
Arospeed Adjustable Cam Pulley
Aluminized Thermal Cloth
Aluminium Pulley Kit
High Capacity Fuel Rail Kit
Honda B16a/B18c Vtec Adjustable Cam Pulley
Exhaust Thermal wrap
Oil Catch Tank - New
Cusco Oil Catch Tank
Nissan SR20 Performance Parts
Thermal Intake Manifold Gasket
NGK Power Cable
Bubble remover tank / Breather tank
Magnetic Oil Sump Nut
Skunk 2 Resevoir Cover
Engine Damper Kit
Power Enterprise Timing Belt
Walbro 255lph Fuel Pump
Turbo Manifold for GSR 4G93T / Evo123
Performance Intake Manifold
Tomei Camshafts
Piper Racing Camshafts - New
HOT BITS SS Extractors - HOT !!
Spoon Reservoir Cover - Nice !!
Transparent Timing Belt Cover
Cometic Metal Head Gasket
Turbo Charger
EXEDY Racing Clutch
TRINITi Racing Clutch - NEW
T-Bolt Hose Clamps
Greddy & Cusco Performance Engine Oil
KAAZ Transmission Gear Oil
Engine Mounting Full Rubber - NEW
**Fuel Injector Cleaning Service
* Dynamic Engine Balancing Service - NEW
JUN Racing Camshaft
Matspeed Performance Camshaft
Jasma Performance Camshaft
RACE-TECH Smooth Shift Bushing
Racing Oil Pump for 4g9x Engine
Dynatek ARC-2 Ignition Booster
Cooling Mist Water Methanol Injection Kit
ACL / King Engine Bearing
CP/ Wiseco/ Supertech (Forged Pistons)
Duratech Con-rod (Connecting Rods)
ARP Head Studs
Engine Oil Cap
Breather Filter
HKS & VP octane booster & engine cleaner
Hi-Tech Stainless Steel Extrator for Honda B series & Mitsubishi 4g9x
Super Single Racing Clutch for Mitsubishi GSR CK Turbo
WORKS Alloy Aluminium TT Crank Pulley
KAAZ LSD Limited Slip Differential - HOT
Intake System & Filter
K&N Drop In & Open pod Air Filter
Apexi Power Intake
Open Pod Air Filter Kit
WORKS Engineering Drop in Filter
Project S Super Stainless Drop in Filter
HKS Power Flow Reloaded
HKS Filter Element Dry 3 Layer
Stainless Steel Filter
Real Carbon Filter
UTR Super Flow Performance Drop in Filter - hot
Simota Twister
Pipercross cold air Intake duct
Cold Air Intake Hose Kit
Intake Air Ram Pipe - New
Aluminium Piping
Mugen Air Box
Electronics
NRG Meters - NEW !!
Shadow E-Drive Throttle Controller - NEW
Shadow Sports Meter - New
Pivot Shift Lamps - New
Apexi AFC Neo
Greddy Emanage
Pivot Speed Meter V
Pivot Raizin VS-E Volt Stabilizer
Apexi Boost Meter
Shift Lamp
V-Manage Ignition Amplifier
Apexi Pen Timer - New
Turbo Timer
MTX-L: Wideband Air/Fuel Ratio Gauge
Engine Start Button - Hot
Ignition Earth
Grounding Cable kit
Direct Ignition Panel
Digital Volt Meter
Electric Fan Temperature Controller
HKS Style Grounding Cable Kit - Hot
Electronic Boost Controller
Silicone hoses :
Silicone Radiator hose kit - New
Samco Silicone hose
Samco Vacuum hose
ASR Silicone Elbow and Reducer
HKS Vacuum hose
Cooling parts :
DEI Performance Coolant Additive - Hot
Performance Aluminium Radiator
Wira, Satria, Putra, Evo and Civic eg/ek Performance Radiator
Honda EG/EK Aluminium Radiator
Radiator Cooling Plate - NEW !!
Engine Oil Cooler Kit - New
Engine Oil Cooler
Intercoolers
ARC Intercooler
Automatic Transmission Cooler Kit
12" Performance Electric Fan
Low Temp Sports Thermostat - New
Synergy Radiator
ARC Aluminium for Proton EVO/GSR and Honda Civic
Braking system :
PRO-RS Braided brake hose
High Performance Brake Pads
Brembo Brake Fluid
Sports Brake Rotor
Brembo Brake Disc Rotor - NEW
VTTR Break Kits
Skunk2 rear lower arm for Honda Civic EG/EK
Interior / Exterior and Body parts :
Works Engineering Gear Knob - New
Bride Low Max Seat
Philips crystal vision
Real Carbon Plate
D1 Bonnet Pin
Sparco bonnet pin
Sparco Rear Pin / Hook
Aerodynamic Number Plate Holder - New
Gear Short Shifter
RECARO Seat DC5 - Black
Suspension parts :
HWL Full Adjustable Suspension - NEW !!
HWL Adjustable Suspension - HOT !!
Adjustable Suspension Kit For Proton Cars
Ultra Racing Chassis Stabilizer Bar
BC Racing Adjustable Suspension - HOT !!
BC Adjustable Suspension
GAB Suspension
Rear Lower Arm bar
Suspension kits for Nissan RWD cars
Honda Adjustable Suspension kit
POWERFLEX Polyurethane Bushing
Rear Suspension arm for Proton Wira, Putra and Satria - New
Room bar
Adjustable Front / Rear Camber & Toe Kits
SuperPro Polyurethane Bushing
HARDRACE Adjustable Suspension ARM
Car Audio :
Focal and Zapco products
Others :
Alloy wheel nuts
Sports Wheel Nuts - New
Oil Temp/ Pressure Sensor & Cooler Adaptor
Water Temperature Sensor Hose Adaptor
Samco Silicone hose key chain - CooL :D
[MAP] Sunway, Petaling Jaya, Selangor, malaysia[/MAP]
Address :
No.7, Jalan PJS11/24,
Bandar Sunway,
46150 Petaling Jaya, Selangor.
Note: Rev Performance (1st floor above F3 Racing Technology), same row as Teck Ming Silverstone tires near N1 racing.
Operating Hours : Monday to Saturday ( 11am - 7pm )
Please pm or sms for COD at Rev Performance, Bandar Sunway or Postage by GD Express ( postage will be charged ).
My contact no. is : 017-3526055 (andy)
Bank In Details :
Bank : Maybank
Account no : 112231051159
Name : Low Chun Hung
More products coming soon !! TQ :burnout:
The Marketplace Top Posts
I've read from another forum that the wurth battery connectors will help increase performance, ice sounds better and many more. Have any of the sifu here used it and is it worth the money spent ??
Drex also mention something about it but there was no conclusion. Any comments appreciated.
Tks.
