help for a32
ming_fei
47
Can any one enlighten me on the following:-
i) what is the sign and symptom if the ignition coil ROSAK???
ii) How to test it??
Thanks
Yu911
425
2
www.cardomain.com
I just change my ignition coil 2 days ago. $165/pc. for front & & $170/pc for back, I change 1pc front & 1 pc back. U can feel the engine jerking & under power as ChengMouKei said, also can feel when stop with D gear, try to let go the break slowly, the car jerkkkkkkkkkkk.
ming_fei
47
Oh.....I see. I had experience this same jerkkkkkking lately, but after a while (travel while jerkkkkkkkking for another 4-5km) it back to normal. SOme time, I turn on the power mode and the jerkkkkkkking go off much earlier (another 2-3km).
Yu911, how u know which one of the ignition coil already "kong" liaw???? How to check???:confused::nurse:
Yu911
425
2
www.cardomain.com
ah ha, senang saja, but only can test when ur engine is jerking, look for the ignition coil wire clip, at each ignition coil, pull out the clip, the engine will jerk more, this show the ignition coil is ok, clip back the cliper & pull other clip out & back till the one is the same (like nothing happen), this show the ignition coil is not working, so this is the one rosak loh, hope this help.
ming_fei
47
Oh, like that ah....then will have to wait for next jerkkkkkkkking loh.
Thanks Yu911:driver:
Yu911
425
2
www.cardomain.com
Yaloh, have to wait till jerkkkkk loh. the 1st. day I got my car & at night my car start to jerk, after 1 or 2 days it come again but only for about 1-2km than ok liau, than almost every day but each time I wanted to check, the engine ok! Can't wait so just buy 1pc back ignition coil & replace at no.1, looks like no more liau but after 2 days come again, so change to no. 2nd. & try, better oh only after 3 days come again but this time every day also got jerk, & most of the time. This time senang to check b'coz most of the time also jerk, than is the front ignition coil, so go to spare part shop buy the foont & now ok liau.
sb3
1,141
14
5,138
Hey guys , dont mean to sound disappointing , but this stupid' jerk'happened to my car b4. i change the whole six coils (new ori hanshin i think). still the same jerkkkkk! Damn. I taught i was alone b4 i join this ceffie site. Wow! i realised its so common this 'jerk' thing happens to our VQ engines.. Is it a man defect or is it just coincidence??
sb3
1,141
14
5,138
My first replacement were the spark plugs and its not cheap!! 1plug rm45-00 X 6 = rm270-00! Nope thats not d problem.
sb3
1,141
14
5,138
how is the jerk feel? no enough fuel? lost power? hungry? thirsty? ecu? atf filter(got filter?)? g/box? sensor?
jerking @ idle, loss of power ( feels like 4-5 cylinders working only)smell of fuel when ignition off. g/box , ok.
Yu911
425
2
www.cardomain.com
meng_fei, is ur car ok now?
sb3, so what is the problem of ur car than? is it ok now?
seizai, is ur boss car ok now?
ming_fei
47
Yu911, I have not done anything yet cos it is temporary OK now but fuel consumption is rather high. Will arrange to change the ignition coil a.s.a.p. And also to replace my temporature gauge/meter, already "Kong" liaw. Need to find a new meter.:banghead:
Notice most family car turbo cars like Merc, BMW, Audi, Volvo, VW, Peug don't come with any intercoolers? For Malaysian weather is it sufficient, or it's bad of the turbo & engine in the long run?
Last time Merc, Audi don't do big boost on their compressor/turbos for lower spec models but nowadays we see most of the has increased the boost to gain more power with smaller engines, which in terms translate to higher stress to the engine & more heat.
You'd see Japanese Turbo cars usually...
