emanage tuning and installation
dweichoe
76
Hi,
i did some survey on emanage. I stil have some doubt on it.
Can Emanage support Wira 1.5MMC ECU?
if can, can it tweak on the "ignition"?
thanks .....
vteckiller
Supporting Merchants
1,606
34
bro vteckiller, thanks for the tuning and dyno hehehe
next time mau add NOS i cari u lagi hahahaha
let me think and cari $ dulu hahaha:driver::driver:
your most welcome bro..
no probs..thanks for lunch :)
NOS soon ...hahahaha
jegvd
1,932
guys,
those who wana add and tune e-manage for turbo car, do contact me. I can arrange for dyno tune as well. Just a e-manage even with ignition harness not enuf to tune turbo car, need to add something to advice the e-manage to control the car follow your boost where standard e-manage can't do that.This will give you more fine tuning and more hp.....
For more details, pm me.
vteckiller
1,606
34
Hi,
thanks .....
yes emanage can be installed in 1.5mmc ecu..
confirm can no probs at all..
for sure thing!
vteckiller
1,606
34
well,to all sorry have not been onlne for some time now..
been really busy..
sorry.will try my best to reply within short period of time..
cheers..:driver:
GroundZro
421
Joshua,Thank you for the tuning. Didnt know wht to expect but after a search on the net, I found out tht my current hp (nothing to shout about) is already higher than those with stock engine (like mine) but on 2wd. Next thing is to sort out the boost controller setting. You should find out more about this controller la.....I believe more and more driver will be using it......
Spoonz
744
bro vteckiller,
have u done e-manage on stock vios?
how much hp increase can be expected? thanx..:biggrin:
btw, whats the different between e-manage blue and ultimate?
Spoonz
744
will it help abit if install muffler + filter + fuel pump combo?
can achieve around 10 hp...?
my kenari is facing (i think) engine oil decrease, it is full when cold morning before start the car, and after engine running optimum temp, i shut the car off immediately and remeasure the oil level, the oil level goes down to half, is this normal?(ps. all measurement done at leveled floor) i heard some mechs said that is normal, and kenari engine oil must be measured right after car engine turned off is the most accurate, if low oil level reading resulted from that means engine oil is low...
