Turbo engines with NGV?
ary4145
44
Hi guys.. ben quite some times neva drop by zth...
Got some silly questions that i need help on
Can i install a NGV to an Evo 3 engine? If can arr is there any problems that can contribute to my turbo?
What will happen f i change my Exaust system (muffler) to standard Perdana type
Hope can get some info from u guys since all of ya are all nice nice wan..
Thanks:wavey:
nokia
456
2
just my 2 cents,
U install turbo just bcoz it have more power. But then u go add on NGV just for FC, what is the point in 1st step ? More power = more fuel.
i will suggest u use that NGV installation money to buy a cheap vehicle to run (like Kancil) and keep your Evo 3 engine alone for fun.
Northiswara
2,589
7
just my 2 cents,
yeap.
or else just plug in a smaller turbo and lean out the AFR to save fuel.
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Thanks:wavey:
You will be able to switch from NGV to PETROL and vice versa easily with a flick of a switch. BOOST use petrol, OFF BOOST use natural gas is it possible?:listen:
huakenny
LB Performance
9,126
240
Kota Kinabalu
E3 use sequential type ngv, fully auto kit.
sequential type comes wit an ECU, it tapped to ur car ECU to get signals...so all the timings is based one ur car ecu..so it is very cun.
but power loss is 5%-10%depends.....
my fren perdana twinturbo is using, smoke ppl tat time wit NGV....if really wan race then only switch to petrol....saves alot. roadtax cheaper 25% oso
nokia
456
2
i have to check with Thailand HKS distributer. Japan not selling it.
bujang_hensem
82
heat is the worst enemy for NGV conversion since NGV burning temp will be around 600 Celcius. vs petrol 400 Celcius..even petrol easy to reach 900deg when boosting so long term maybe if like to boosting alot the valve and exzos manifol and turbine could crack. I'm thinking as well to put in ngv to my 4G63t but maybe will cancel my booking due to heat issue and hard to fine good tuner...FYI most of the NGV injector only can support up to 50HP ..so 50x4 = 200hp max...if 6 piston no problem since 6x50=300hp...
so injector up to max also problem for turbo car unless your car <200hp...
gtauto
18
Guys do you know that NGV has 130 octane? Which means to say if you tuned it right on a turbocharged engine, it will give you more power than petrol. You can even boost higher because its 130 octane. It will be like using racing fuel.:burnout:
Today we are working on the brand new Mazda CX-5, already impressed with the looks and all, we are excited as we are going to make her into a mirror! The coating we are using today is a custom formula developed by us over the years of experience in this industry. For more info, you can simply PM, E-mail or Whatsapp to us direct as this is not a sale post but a article featuring this ride's process...
