bolt on turbo for my car
shashitharan
to all sifu's cani install a turbo tp my 4g92p soch.. please advise me wat should i get if can bolt on.. my engine is using 4g93 pistons
change ur piston to gsr 1.get a thicker metal gasket,look for td04 turbo incl
manifold for direct bolt on,get a better fuel pump n fpr,i/cooler,bigger injector
and a piggyback to manage ur fuel n ignition.what else.....:hmmmm:
anyone else wants to add?
Erm, bigger exhaust? colder spark plugs? custom intercooler pipings? how about stronger internals for higher boost? grippy clutch plate? dyno tune? :hmmmm:
Block? No need to change? Or 4G92 block already got oil squirter.
imo,it's not necessary if ur boosting below 0.8bar.there's a few 1.6 bot
running around w/o it.if got,better la.:)
we got full metal gasket for 12v 4g13/15 rm240 1.0mm....semi metal mmc 2.0mm rm175....name it what you want...intercoler,injector or custom banana...we dont this project
there's 1 runing w/o piggy.other's i'm not sure.ur engine is running on maf so
it's much more easier to bot.
what about Civic 1.6 SOHC then? I heard this engine can use vitara's pistons right? how much is it?
Hi there..
Better u find completed gsr 1.8 turbo head + turbo + gsr intercoler + turbo host and metal gasket . Now cos around 3 k if u lucky...last time coz around 1.5 k. Then add external fuel pump + e-manage.
done.....
Or 2nd option, find gsr injector, gsr turbo completed with maniful , metal gasket, turbo host, intercoler, external fuel pump , e-manage.
done
Then 1st optionu will get twin cam turbo and 2nd option u will get single cam turbo.
main thing is money.........
gud luck bro
hie there..
mine is 4G15, m planning BOT for it b4 i change to a bigger capacity..wht do ya'll recommend me?wht r d thing i need?
hie there..
i seen alot of 4G15 BOT but the power outcome will be very limited as well...so better to change to a twin cam engine...
limited power means????can compete stock putra urh?
juz wanna play around wif mah frens car..
4g15 bot can play with stock putra lah... but once ur friends start upgrading their rides, u are left way behind... besides, since u are dumping in 7k-8k for bot turbo kit, why not spend it on a 4g93p (putra or sgti engine) engine... if u have a few Ks more, get a 4g93t gsr, which has even more potential...
but if u are looking into how much u can max out ur 4g15 without worrying on the budget, by all means go ahead...
sifu has spoken................
