About owning a S2000/F20c engine
whitelighter
39
1,508
I wish to own a s2000,its nice.but to get it in future,i would like to know how more about how and how much does it need to maintain it per year.The engine,does it make any problem? and if possible,i would like to know more about honda's engine,cauz i don know much on honda's engine.thx
fobs
3,752
future,... as in? as when?
ooohhh,...
owners of the s2k,... rare here,...
bien335
1,819
48
1,648
Johor Bahru
maintenance wise, Honda engines are farely easy to maintain. And being a Honda, it'll last a lifetime. There are many owners of the S2k that have clocked more than 250k miles (400k km) without much problems.
and the F20C is not the same as the F20B in the CF4 Accord. The F20c is more closely related to the K-series in architecture.
F20C (JDM spec, AP1)
bore x stroke : 87x84
250PS @ 8600rpm
208Nm @ 7500rpm
F22c (JDM, AP2)
87 x 90.7
242PS @ 7800rpm
221Nm @ 6800rpm
shiroitenshi
3,676
170
whitelighter, like bien says, the stock engine practically lasts forever, as you can see from the various converted B series civic, H series accord, F(ob's) series DOHC accord, and etc.
It's when you modify it that reliability is compromised.
But even with a bit of abuse, and clocking 200,000kms, I've only lost compression on ONE piston with the rest reading on par with a healthy engine., which is pretty much a good idea of how hardy the engine is. I doubt that many honda engines see critical failure with minor maintainance done every now and then (it will cost a bit, but if you can buy an S2K, I think maintanance would be a non issue in terms of financial capacity, after all original honda parts are expensive, but not THAT expensive as some aftermarket JDM parts.)
Well, the ball is in your grounds, and your choice.
fobs
3,752
^^ LOL @ F(ob's) DOHC engine.
good one.
+1 rep for you buddy
supposed to be fobs'
weihhh,... my initials lerrrr,... dun take away the last alphabet,... then i would sound like a guy from mainland china,...
uuuuuuuuhuuuuu!!! my rear injured,...
anyway,... how come we dun see s2k owners here???
raining
188
10
kuala lumpur
I'm S2k owner,the car has lesser torque,not a daily car,you only drive it when you are angry,or happy. When approach 9000rmp,the engine screams angrily,makes people scare,excited,but would make other drivers annoying,being challenged..The car has supreb handling,sensitive steering,and the 2nd gear reaches almost 100km/h. The ready to race position makes a racing environment you can't get from other japanese manufacturers,and the bucklet seat only fit slimers well.
raining
188
10
kuala lumpur
the maintainance of the car is just like many other japanese car,5 litre engine oil,replace new motul LSD gear oil every 20k kms,change rear sharf LSD oil every 50k kms,and the overall fuel consumes about RM0.17/km. But DO NOT let normal workshop handle the car,DO NOT let ur no brain friends test drive it, the car needs some practise to master it. And,don't try the car in corners on the road,it's the 2nd hard to control car after lotus elise.
fobs
3,752
wow bro,...
9k rpm,... !!!
paul.ang
43
2
3,008
What Raining said is absolutely correct. Maintenance is no big deal. And yes, it's tricky in the corners. I never did like driving mine on the stock suspension but a set of Bilstein PSS9 coil-overs & Bridgestone RE-01Rs transformed it.
paul.ang
43
2
3,008
Anyone know any difference between straight-out pipes and pipes with box?
straight-out pipes will be more noisy? or eatin more petrol?
