B16B Block, what crank & rod to put in?
E-Tech
1,115
256
3,183
Johor
Hi guys...
Need some input or inputs...
Have a B16A in da car now...with CTR cam and valves..
Have a B16B block with all the insides....
Have a B20B block with all the inside frm crv
Can get a b18c crank and rod....
What are the options I have for best combination power & durability?
Cost saving - b16a piston, b16b block, crv crank & rod- >1800cc
Spend some more $$$- b16a piston, b16b block, b18c crank & rod- <1800cc
How? What would be the best option base on the available stuffs above?
Thanks in advance for input....:biggrin:
simplycomplexed
76
redorzero.blogspot.com
i think... b16b would be nice. with all the insides. : D
b20b has lower compression so i wouldnt like it.
throw away the b16a? : p
(please dont fire me, i lack knowledge.)
Zeroed
1,706
45
B20B has smaller conrod bolts which are not suitable for high revving, so I wouldnt use those... (if the bolt stretches at high rpm you may spin and destroy a bearing, one of the reasons why B20B hybrids always fail. )
B18C conrods, bolts and pistons would be your best bet I think. B16A pistons will apparently give you 11.6 compression with stock gaskets which is a bit high...
By the way. Does anyone know if the B20B's block sleeves can withstand high rpm VTEC operation? With proper internals...
hattech-v
Over 10,000 RPM!
12,756
12
Seri Kembangan
www.avantech.com.my
using the right piston, oil squitter, proper afr tuning, balancing, good valvetrain can withstand high rpm revving for b20b...
but again, sometime depen on ur luck... got ppl using b20b standard internal can withstand up to 3 years n some blow their engine right after finish their running in... haha
E-Tech
1,115
256
3,183
Johor
My application will be for "sometimes rev-ing rev-ing"...
Well for B20B conrod bolt matter, I read it somewhere too....
dcloo
1,784
17
kl
b16b oversize big bore piston 83mm + block guard will suite for u rev-ing rev-ing
maybe u can get 200 whp depend on ur cam+bla bla bla setup
E-Tech
1,115
256
3,183
Johor
DCLoo...
However B16B oversize to 83mm, B16b crank & rod= 1675cc
If B16B oversize to 83mm, B18c crank & rod= 1888cc nicer right... and maybe good & lasting high rpm revs..
So anyone has this set up?
simplycomplexed
76
the b20b's sleeves are manufactured at 84mm instead of the 81mm on the other B series. i think other sleeves cracks more easily than the b20b one.
Zeroed
1,706
45
Eh you mean the B20B one cracks more easily? Or that if the B16/B18 is bored to 84mm, the B16/B18 ones crack more easily?
Im really tempted to venture into B20B in the future but the sleeve durability and affordable pistons are my concerns. I heard that the B20B sleeves are built using a different material which will not be as durable as B16/B18 sleeves bored out to 84mm as well, but Im not so sure about that...
hattech-v
Over 10,000 RPM!
12,756
12
Seri Kembangan
www.avantech.com.my
DCLoo...
haha yes yes the number using b18cr one is very nice....
but u have to remember that b16b have a much better rs ratio compared to b18cr..
b16b = 1.85
b18cr = 1.58
hattech-v
Over 10,000 RPM!
12,756
12
Seri Kembangan
www.avantech.com.my
not only the sleeve, the block housing oso tend to crack...
mine got hole sumore... 50cent hole.. haha
Zeroed
1,706
45
Aiyak now block housing some more? lol
Did you do any modifications to the internals or just plug and play as standard only?
edit: Saw some pictures of different blocks onlnie. Seems that the B20B has bigger sleeves altogether, the original B16/18 ones wont bore to 84mm so I guess B20B is the only way without resleeving...
hattech-v
Over 10,000 RPM!
12,756
12
Seri Kembangan
www.avantech.com.my
b16b/b18c/b18b all can go up to 84.. 85 oso can if not mistaken. the only thing is u dare to do it or not...
block guard is a must then... but still will become very fragile..
mine considered mod with oil squitter, piston n rod balanced, type r block brace, type r oil pump, b20b crank, ford 84mm piston, internal vtec oil line, b16a bored 84mm head gasket.
hattech-v
Over 10,000 RPM!
12,756
12
Seri Kembangan
www.avantech.com.my
ops... forgot to tell.. the engine dia at 7000rpm after serving me 3400km.. one piston gone (not crack or creating hole). its totally destroy.. then a piece of the piston going down to the crank n being kicked out n making a 50cent hole on the block.
no issue on not enuf fuel since i'm using RC 440cc injector with only 60% injector duty cycle being used.
Zeroed
1,706
45
E-Tech
1,115
256
3,183
Johor
Wah... getting serious lah.......
One question pls... 11.6 C.R consider too high for hondas?
(use b16B piston with b18c crank n conrods)
Use to build mivecs at this spec....
Understand B16b has better rs ratio... but need to up the cc too so no choice.. SO cannot rev like motherf##ker lor but maybe still can sream like a pornstar.... lol
J101
1,304
malaysia
hattech
im asking on behalf of myself
where to get the brand new ford 83mm pistons with a good price? thx
the liner can go up to 86mm before leaving only the sleeve.
ford na piston inside b16 n b20 is common...
b16 normally use 83mm one.
A Post Every 5 Mins
SORRY...:adore: hope..i'm at the right place that i should post this......
MAZDA.....owner not happy with his car engine bay...after done major overhoul engine,my friend send this car to me for detailing work,and make all my own car work stuck...:banghead:
As usual lets all the pics talk.....:listen::proud::itsme::eviltongue::thrasher:
