Engine Conversation. Full halfcut ? Engine only ?
m@ttz
1,846
13
klang
MIVEC RS has all like what you have mentioned. Plus the front brakes must be 2 pot calipers. Internally, it should have titanium valves, slightly bigger extractors and slightly higher cams with different ECU where the MIVEC kicks in at 6200/6500 and standard rev cut is at 9000. Remember to change your fuel pump or use the MIVEC original fuel tank because our standard fuel tank is not enough at 8000++RPM....
thanks wajafly, dat was internally, the simple thing is bring someone expert or whose know well when buying engine / halfcut
so norns, wat engine lantai u planned for?? is it mivec??
Norns
497
m@ttz .... im very into going for mivec .
btw as for my plan, which is engine lantai + fuel pump ... is it sufficient enuf for everything ma ?
for brake n dashboard n those that not-a-must i can upgrade slowly lor
imprezas
32
great dude.. i was thinking to convert my car to mivec too.. ur tread help alot.. :regular_smile: now just finding the right chop shop to buy and install.
m@ttz
1,846
13
klang
wat price u can get 4 mivec engine lantai?? for me, seems finally u will use thousands $$$ also, better go for halfcut, less risk, by halfcut everything inside there, just pnp ma n kautim..
but its up 2 u, any sifu suggestion??
mag9556
2,770
43
1,648
i m not sifu here..hehe...but half cut better as said b4..
there will be some extra sometimes..
Good Luck..
Norns
497
im not sure the price also lol >_<"
Btw, halfcut price is around rm6500 ... can i know rough price for each parts ?
afaik,
- engine and its part includin trottle body,injector,intake m : rm 2000 ? rm3000 ?
- gearbox mivec lsd : rm1500 ?
- disc brake : rm500 ?
- dashboard with meter : rm700 ?
- door panel : rm300
- any else missing ?
Wajafly
159
Shah Alam
You sure gearbox MIVEC LSD can get RM1500? Standby at least 2.5K for the lsd gearbox only. Then, clutch and flywheel? For good one like Exedy standby 900 for clutch alone.
No matter what, it is not safe to buy rojak parts by parts for a proper transplant. Get a halfcut and standby around 3K for parts like timing belt, clutch and other things like mountings or bushes...
Norns
497
emm is LSD a must for mivec ? @_@
addon :
- fuel pump : ??
- fuel tank : ??
- bonet, bumper and some body parts : maybe rm400 ??
can anyone correct me more @_@
Wajafly
159
Shah Alam
LSD is not a must for MIVEC but it will be an advantage to have one. Minimise your wheel spin during drags and gives better high speed corners.
fuel tank use back standard MIVEC and no need fuel pump. Why want body parts?
QiW
6,105
5
engine lantai = ENGINE ONLY .. nothing else .. even manifolds and throttle body tarak one laa ... no wiring no nothing .. just BLOCK and HEAD only ..
unless someone just kaboom their current engine and wanna change back the same engine .. always get a halfcut if u wanna change to a different model of engine as almost everything u need will be there .. some even include fuel tank or fuel pump and rear discs brakes ..
dont ever take a loan to transplant/mod car .. i have seen ppl doing that and ended up selling the car and still owing lots of $$$ ..
Norns
497
so confusin le @@
if engine lantai = engine only , what bout engine kosong ?
engine lantai = engine only = engine block + engine head ?
Btw, cna anyone confirm all the prices i roughly quote in #46 ? ^_^
if my loan all goes smoothly approve, by next month my mivec will be on the road !!! :D
mag9556
2,770
43
1,648
so confusin le @@
Aiya...nearly the same la..just a bit of extra things onli.. check with chop shop they will let u knoe abt this..
MIVEC oh!!! folks becareful oh!! another MIVEC on the road...hahahhaha...
areyoon
6
If change 4G13MT to 4G15AT engine, what document need to submit to Puspakom and JPJ
mag9556
2,770
43
1,648
Arh... regarding this arh....
1st u have to buy engine with the engine custom paper lor...
2nd submit the custom paper to the JPJ HQ to take letter of approval lor and dun forget to mention change to auto..
3rd after approved... change engine and send your lover to Puspakom for inspection and change the garen..
If under loan, need a letter from the bank...
It is better that u gave all those thing to runner to settle.. less hassel..
Good Luck...:biggrin:
Norns
497
any idea which workshop is specialize in transplant with good workmanship and reasonable price ?
share some experience how u maintance/service or repair ur car,their attitude,hand work,responsible n kind.so u know wat u have done with ur lovely ride?pump
