eyong.....u little devil....Maybe go for the newer GT3071R, ball-bearing (CHRA). Check it out here:
TurboByGarrett.com - Catalog
*Pssst, I want two of them ....*
This should be the E34 with ori engine + bolt in turbo!!Guys, here's the link to all the pics of USTC 2007. Chicks pics included....
http://www.zerotohundred.com/newforums/your-shots/155004-ustc-2007-pics-and-chicks.html#post2195188
Joe34, u Bimmer should be like this mah....
wow.......the amount spent on rebuilding the engine can buy u a house ......TR heheh.....:regular_smile:KK, you will pengsan when i tell u the figure.....................
1000BHP..........:shocked:
it will work....but the thing is.....the......blower is going to rob the engine's power at certain rpm.........you are not going to get the best of both world.....by having that kind of setup.......nth is perfect........:regular_smile:If you guys think that Bimmer is crazy, you should check this out ...
Wonder if it really works ??? :confused_smile:
true......but the power output with the blower does not necessary mean its going to be higher....it could be slightly lower than the two hair dryer........itself....but the advantage here is the time taken to spool up the two hair dryer will be quicker with the blower .......:regular_smile:I personally thinks it's overboard .... With a twin GT3040 would easily push over 1000hp plus the blower, it's just sheer madness ....
Too bad for whoever running this set-up is the driver's gonna be as hot as the engine .... hahahaha ...
