Looking for secondhand mivec piston.
Latebloomer
89
4
27
Finally some answer. It had been awhile since i have chit chat at this forum. Ya was thinking on getting the semi forged piston but will it be worth it compare with the art brand piston?
brokenjars
229
16
Kedah
Why are you changing your pistons? Is it blown with your current usage?
If normal usage normal compression like normal factory spec, any pistons is ok i think.
If going for high compression, semi forge better. If conservative tune, normal pistons also ok.
If turbo, forged pistons.
Latebloomer
89
4
27
im goin for high compression set up... the old piston are okay and all.. im doin general overhaul on my engine so i was thinking on changing the piston on the way go
nw111
81
34
Terra dei Motori
Fatboy Racing (search on FB) might be able to help you.
The Marketplace Top Posts
Hi Guys,
I would like to have some inputs from those had used it, been using, stop using or just anybody know about this. I know that electronic throttle on modern cars nowadays using pulse signal to control the throttle opening well thats in a layman term. So as for my readings and understanding, this throttle controller will somehow make the pulse response better?
So my question is, I am interested and considering with Pivot throttle controller, i just want to know, how efficient it...
