Preferred Piggyback ECU for 1JZGTE VVTI.
Mitevo7
1,456
179
@Mitevo7 come join us la.
This date i can't, family dinner, next one lar, and also give me more time to tidy up the car too, got some loose brackets somewhere, tak tak tak tak tak like something rattling in the engine bay.
Thanks,
Ken
Mitevo7
1,456
179
im not saying that u cant use emanage blue... just that device capability not worth going to map sensor based...unless the tuner is definately able to smooth things out on every driving occasion...
If my target is 350whp, without going MAP conversion, can the emanage BLUE able to do it?
Thanks,
Ken
Thanks,
Ken
I doubt you can get that number without a turbo upgrade. My setup had a single large turbo standalone ECU setup to get 360whp with lots of supporting mods (top feed injectors, fuel pump upgrade, injector upgrade, etc etc)
Mitevo7
1,456
179
My plan is to hi-flow the CT15B, standard boost at 0.9 bar, scramble boost at 1.4 bar to get to 350whp when required. The modder’s suggestion to me, larger fuel injector, better ignition, spark plugs, after market BOV to get to that numbers.
Feasible ?
Thanks,
Ken
Feasible ?
Thanks,
Ken
Are your current injectors side-feed? If so the mod will require a fuel rail and top feed injectors. Ignition coils no need to upgrade as stock is already quite good unless yours is worn out and get a GFB or an ori Turbosmart BOV. Those are awesome.
As for scramble boost I'm not a fan as I believe it kills the turbo much faster. But if modders have done it safely and worked well for them then yeah why not? But just be warned that pushing anything above it's maximum state is not going to do it favors.
Mitevo7
1,456
179
Stock everything down to stock BOV. I need recirculating BOV setup, otherwise loose power and idles like shit.
The scramble boost will be done only i modified the CT15B with steel fin. The stock ceramic fin is weak.
Thanks
Ken
sweelt
Nov 6, 2016
2,306
248
I am not looking at crazy power upgrades (YET) but wanted to optimize the AFR. I had modified all the, exhaust, downpipe, intake and intercooler pipings when converting the engine in a E46 chassis and i am pretty the air flow measurement is slightly off compare to stock tubes. My gut feelings telling me that the current engine performance is not optimal yet. Idling may be stable but during drive, the acceleration is kinda off as i am expecting even stronger pull.
I have 2 options now, Unichip Q and Emanage Blue, obviously Emanage blue is not everybody's favorite so i will pass on that. What do you guys think of Unichip ? Last time there was this RS Tune used to tune Unichip in Puchong.
Thanks,
Ken
As many upgrade you do, the engine still in stock mode iinm. Keep it that way for a moment. Correct me if i'm wrong.
Calm down and plan lah, have a kit kat.
Modder can tell u this and that. Anyway you the final decider....lol :biggrin:
Mitevo7
1,456
179
That's the beauty of stock 1JZ, bolt on mods can have so many effects on it. Just checked again myself, if i am not running over 500hp MAP sensor is pretty much unnecessary. I will change title to Prefered Piggyback ECU for 1JZGTE VVTI.
Thanks,
Ken
Thanks,
Ken
Done. (the rename)
There isn't a lot of piggybacks out there for you to choose that can handle 6-cylinder. Personally I'm not a fan of the piggyback only because I've seen what standalone can do and the pricing whilst more expensive, makes it more worthwhile in comparison.
Mitevo7
1,456
179
Done. (the rename)
Thanks dude ! Reason i am routing for Piggyback for now is because there were 2 ready for me to install at very fair price. Emanage Blue and Unichip Q. For Unichip Q to perform better, i just need to buy another turbo module. My questions now are:
1.) Which one has more "Know How" people in the market to tune
2.) Which one performs better when i decided to go beyond 350whp
3.) Which one is easily removed so that i can go for standalone, if i have the money :biggrin:
Thanks,
Ken
Thanks
Ken
Why would the BOV affect idle?
Thanks,
Ken
1. both Unichip and Emanage have huge support in KL. Both have huge followings.
2. both work. Unichip will need that module. EManage however I'd recommend you go higher end like Ultimate.
3. both will need to splice your original wires so switching to standalone might be messy
ixeo
4,788
3,080
KL, Malaysia
Mitevo7
1,456
179
Stock 1jzgte VVTI uses recirculated BOV setup. The HKS SSQV that i had is vent to
atmosphere setup, and since i am still using MAF setup, the vented air will cause the engine to run rich.
Reactions: sweelt
The Marketplace Top Posts
Care and Feeding of the Porsche Clutch
by Paul Lighthill
A recent call inquired about severe clutch chatter in a Carrera 2 that had only 30,000 miles on the odometer. It has been my experience during forty years of dealing with things mechanical that the operator is the single most important factor in determining a machines longevity and reliability. Perhaps nowhere is this more apparent than in the clutches and transmissions of our favorite cars, where PIO, or...
