Spark Plugs
I remember reading that the iridium tough can last up to 100k km, not the normal iridium, right?
100k km is insane. Denso Tough claims that? I'd like to see that happen without any performance drop. That would be seriously be impressive
ixeo
4,788
3,080
KL, Malaysia
Why? I have used both and honestly can't really tell which one better.
In my use case, NGK didn't foul as easily as Denso. But just my personal feel la. But now I am using Denso cause easier to source.
I only tried Denso iridium before, because of the 0.4mm tip. First set lasted quite long but when car started to jerk, then change to 2nd set. 2nd set did not last long as one piece the ceramic chip off, then back to platinum due to costing..... :smokin:
Denso easier to source or your specific model of Denso is easier to source.
Never used Denso on my cars, so far only NGK stock, platinum, and Iridium. Now only on stock replacement. Last time (very long time ago) i buy a set of NGK platinum for RM40 and NGK Iridium for below RM100. i buy from distributor.
I have used Denso before on my EX5....didnt notice anything different in term of reliability.
ixeo
4,788
3,080
KL, Malaysia
Wah, next time try NGK la. See how.
Denso easier to source for me. Never bothered, I don't think its that big a difference. But if both NGK and Denso is in front of my face, I choose the cheaper one. If both same price, i choose NGK.
Now on NGK normal and probably next will be NGK Platinum.....lol
UniKorn
9
40
Bro, any difference between Platinum and Iridium?
The price & replacement interval. Iridium is more expensive and claimed to have longer life span.
If your plug is a bit hard to access like on some V engine, boxer, etc....might as well use Iridium as u will save money on labour cost.
If just running normal 3 pot, 4 pot then normal plug is good enough.If gatal tangan then buy platinum, if gatal wallet then buy Iridium.
Reactions: vr2turbo
UniKorn
9
40
Roger that.
Just curious,
For a platinum plug, what's the typical lifespt. 50k km?
Iridium 100k km?
ixeo
4,788
3,080
KL, Malaysia
Roger that.
Just curious,
Iridium 100k km?
Typically. But best to follow owners manual because warranty.
I used to use NGK on all my Mitsubishi because the stock original plugs that came with the cars were all NGK. Now using Mark X, I use Denso coz the original one a is also Denso. On the Swift is also using Denso. Had tried HKS on my X which is ok also but not sure who made it, I suspect it's NGK. Oh the Livina original plugs I think is NGK so I just follow.
For my Chery SUV it came with Bosch 3 tip electrode, search around cannot find, check with Bosch only one shop in Ipoh still having some stock, then went and check alternative and saw it was NGK platinum and that is what I am using now and easy to find.....lol
wow...a normal car which require 3 tip...maybe they used that as a marketing jargon at their homeland.
Do you guys know where i can do rivet nut installation on the chassis? Planning to include more mounting points on the chassis for stiffening bars.
something like the link below
Pelican Technical Article: Installing the Lower Cross Brace on Your BMW
