Evo 2, with 8.5" flywheel?
shah123
Sep 4, 2014
6
Hello guys.
Because the unstable oil price,
Just want to ask a few question, i plan to use 2wd gearbox, remove turbo kit, than running NA.
1) Do Mitsubishi Evo 2 engine, use flywheel 8.5" ?
2) What is the Pro & Con if i'm using 8.5" ?
3) Or the other option, skim the gearbox to maintain 9" flywheel?
what is the best guys... need help. TQ :itsme:
lsm1991
1,469
185
not answering the question at all but... if you have a evo2 engine and want to cabut the turbo, i would instead suggest you sell the car then get another...
probably more viable financially speaking.
Yup, agree.....:driver:
sweelt
Nov 6, 2016
2,306
248
Hello guys.
+3
stock evo2 engine ? or mods ?. In what chassis ?
pls consider deeeeply. :driver:
sweelt
Nov 6, 2016
2,306
248
Just lil bit mods.
Change high comp piston. only that.
In body Wira.
suggest u find n/a engine to swap. Such nice engine cannot downgrade lah.
Such an insult to evo 2. :adore:
You should have mentally prepared, running this force induction engine hard to kira kira petrol price.
or your evo 2 engine got problem ?
shah123
6
Got problem bro.
Last year my piston was broke up, block need to rebore 86mm,
then going to 1jz high comp piston. Try to running NA.
lsm1991
1,469
185
Got problem bro.
ahhh this explains sooo much
sounds like its gona be alooot of work to convert to na...
Hi! Is it possible to convery Campro engine to use cable throttle? I am using Haltech Sprint 500 ECU.
