Myvi Spring Crack
Since we're on Myvi suspension discussion here - can I ask how long does Myvi front absorber mountings last? Mine don't seem to last long and mine is completely stock. Every damn year it breaks. Is that normal?
sanekit
Dec 9, 2015
1,616
157
what brand u use ya? iirc, get original perodua/daihatsu or schmaco. others breaks very fast.
RENESIS VIII
7,063
950
Ipoh
I thought you always hang around your mechanic's place when you service your car, then you should have seen how they take the absorber apart....:driver:
So far I haven't seen him doing much on suspension related work. Only seen before once where he replaces the rear absorber from a Saga knight aeroback.
jerrysiow
407
146
Seremban
I've changed mine to Alza's bearing absorber mounting for almost a year, so far so good. It costs me around RM140 (pair) with installation. I won't go back to original or other OEM myvi rubber mounting, it's suck!
PS: After you've change to Alza's bearing mounting, the car height is slightly higher and you will feel firmer ride during cornering (this is for sure!).
RENESIS VIII
7,063
950
Ipoh
Just like my ex wira, got cheapo, OEM proton and Mitsu ones......:driver:
Nowadays finding Mitsubishi parts to fit Wira seems hard at Ipoh. I wonder if it is still easy at KL to source Mitsubishi parts for Lancer/Mirage to fit Wira?
I am using Schmaco la.
Firmer is fine but higher? Hmm... I might try this. But 1+ years is how long my abs mount lasted. And bearing mounting? I'm referring to absorber top mount
RENESIS VIII
7,063
950
Ipoh
Wira, not sure dy, lost touch......:smokin:
Recently found some lower arm and control arm for sale at mudah with Mitsubishi Genuine Parts label on them.
I got ask my mechanic if can find lower arm and control arm from Japan or not nowadays he say most likely cannot.
Half cut loh......:driver:
jerrysiow
407
146
Seremban
Yes. The ride somehow higher after installed. Yes, it's bearing type absorber top mounting. The rubber type is going to loosen after 3months installed. You can take it out and you will notice it's loosen 1, longgar here and there (no firm at all) and causes the ride floating during corner or high speed.
I've uploaded the image of rubber and bearing type. Hope this help you.
eh exactly. Myvi uses the rubber type. So the Alza one is the bearing type? Looks like an option. Will look into this thanks!
The rubber ones will have bearings too, right? If not, how does it turn?
What’s the deal?
Naza-Brabus, the exclusive sole distributor of Brabus-tuned cars and Brabus performance parts in Malaysia has taken the opportunity to preview its Startech Refinement program with the local debut of The Range Rover Evoque Startech. The exclusive event is part of the many activities held during the Naza Merdeka Auto Fair...
