Myvi Spring Crack
RENESIS VIII
7,063
950
Ipoh
I noticed that my Myvi had cracks on both springs for the front suspension. I don't think this is normal and is it dangerous if I leave it this way?
Here are some photos of it for both right and left side.
Thanks for all your feedback and help.
Right side
Left side
jerrysiow
407
146
Seremban
Nope, it's not crack on the spring itself. The cracked one is the rubber covering the spring, so no worry.
Erm.. Could you clean that part of your spring with water and soap just to confirm it's not the spring? It looks very unlikely a spring crack but just to make sure just clean it up, and retake the pics.
RENESIS VIII
7,063
950
Ipoh
Okay. I'll try to clean up that part.
jerrysiow
407
146
Seremban
I 99% confirm it's the rubber cushion cover cracked. My friend previously notice this and very worry. He bring me along to workshop to have a check on the "cracked" spring. After taking out the absorber and found out it's the damn rubber cover. I checked on few myvi with original absorber, they're the same "behavior".
PS: RM20 workmanship buta-buta bayar.
RENESIS VIII
7,063
950
Ipoh
Better make sure, but I doubt that it is the spring cracked. Some part quite bad already and should have snapped if already cracked....
You got point in this. After checking back some old photos taken during wheel rotation from last year, I noticed that these cracks are already there. Most likely it is the rubber that is cracking then.
Once again, thanks a lot for your help.
But the RM20 workmanship charge is expensive. Don't go to that workshop anymore. :biggrin:
jerrysiow
407
146
Seremban
The workshop is reliable and quite cheap. The workmanship including taking off and putting back the absorber + wheel alignment . Just don't worry, your oem spring is still good.
RENESIS VIII
7,063
950
Ipoh
Oh, then that is okay. I thought just go and check after removing the wheels then charge RM20. :rofl:
Courtesy of several European magazines, twelve high-resolution images of the all new Land Rover LRX concept have leaked online ahead of the crossover’s official debut. In the first half of this year, Land Rover released a single teaser image of the two door SUV. It will be on display at the Detroit auto show.
Its styling seems to be the same as the recently revealed BMW X6. This seems to...
